GE Spacemaker JVM1640SJ Microwave Oven Logo
Posted on Mar 27, 2009
Reset shows on display of my GE space saver microwave oven
Don't know model of space saver microwave but purchased in 1983. Dimension is 13" deep and 30" wide. Unit sits over cooktop. Unit will not function. No response when any buttons are pushed. Display just says "RESET" I shut off the power to the unit hoping that it would reset at start up, but it didn't. Any suggestions?
  • jeffrey gallagher May 11, 2010
    the model is on the door when you open it on the edges of frame are door need it
jeffrey gallagher
Level 1:
  • Contributor 42 Answers
  • Posted on May 08, 2009
jeffrey gallagher
Contributor
Level 1:
Answers
42
Questions
Helped
27158
Points
93
Change the board that has the reset on the display board it is bad
My Panasonic Microwave Dimension 4 Convection is showing FFFF in the time display when I try to use it. What does this mean?
https://www.manualslib.com/manual/652153/Panasonic-Dimension4-Nn-C988w.html
FFFF is not mentioned in the user manual, but there may be some helpful information or contact information in it.
PANASONIC Dimension4 NN C988W Operating Manual And Cook Book
This is not certain, but it may be a part that is expensive to replace according to this other web site for a similar model Panasonic oven. That person said their microwave was still working.
https://www.justanswer.com/appliance/6045n-good-day-panasonic-dimension-iii-microwave-convection.html
Good day, I have a Panasonic Dimension III Microwave/Convection Oven 1983
Model NE-9910A.
I went to use it today and when I entered to nuk my coffee a FFFF display appeared where the clock normally appears. I went and found my operating instruction booklet and it indicated to "stop/reset" which I did. Next it indicates to contact a Panasonic Servicecenter. Can you help me out? ps. It still works great!!!!!
Answered in 1 minute
12/24/2011
FFFF means that your display control board has an internal short. The only way to fix the problem is to replace the display control board which is no longer available. If you really wanted to fix the microwave you'd need to remove the display board and mail it to a place like Appliancetimers.com to have the part refurbished. The cost to have the part repaired is usually about $200-250 or so.
---------------------------------------------------------- Good day have Panasonic Dimension III Microwave Convection
Ge space saver microwave oven Model number HVM1540SN2SS. Interior fan turns on when door is open. This just started yesterday. Please help
The possible issue may be some door sensor broken or work abnormal. Double check three door sensors, especially for two door sensors who are working on normal close state.
Microwave will not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
l'l'l'l'l'l'l'l'l'l'l'l'
3helpful
I have a GE space saver Model JVM3670 - it is not heating up
Generally if everything else looks like it is working fine, then the magnetron has quit and needs to be replaced. The magnetron is the part that heats the food. Unfortunately, it is common for this part to fail on GE microwaves and it isn't worth replacing as the cost of the part is almost the same as buying a new microwave.
Let me know how this works out for you.
Benjamin
WE have a JVM1650SHO5 space saver GE Microwave Oven that suddenly started not heating. No other issues.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
GE space saver Microwave not heating
heatman101
Surface and night light bulbs
If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
Code on the space between oven and microwave
It's normally about 30", but that info will be in either the installation manual or the owner's manual, depending on the brand you choose.
You mention SpaceSaver, that's GE.
You can download GE owner's manuals and installation instructions here.
GE over the range space saver microwave
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
