Hi can you send me a copy I inherited this microwave and would like the manual pleaseHi can you send me a copy I inherited this microwave and would like the manual please
You can't post conmments that contain an email address.
Your question is not really quite clear. What kind of sound is supposed to produce a microwave oven? It works or not? Heats or not? If it won'r work take it to repair to s qualified microvawe repair tech.
Hi Tony , sorry its not much of a solution but try partsmaster , i'll post the link to there inquiry form ( ive used it many times before and whilst there a bit pricey there usually very good ).
ProLine ST44 950 Watts Microwave
Since this machine is only sold in the UK I do not have a picture to point you to.
The problem is probably a blown thermal fuse. This fuse is located inside the machine and is for detecting overheating and fires. Sometimes age will cause it to fail. It's generally located near the air vent outlet.
If you handy with fixing gadgets you can check it.
Unplug the machine and remove the cover.
You can take an ohmmeter and test it. If it shows open you can replace it. It may be soldered in I am not sure. You can get replacements at an appliance parts store or Radio Shack®. There may be conventional fuses inside so you can check them also.
If nothing else is wrong it might be a door switch problem.
Wear on the interlock causing the crowbar microswitch to short the line and blow the internal line fuse. The interlock, required by law, contains 3 switches - one switch sends a door-open signal to the microprocessor, one opens the line and the third crowbars (shorts) the power leads to the magnetron. If the crowbar switch activates before the line switch opens, the line fuse gets blown. Just toss the crowbar switch.
