If the hard drive failed you will first need to replace it with a working hard drive. One that is done, power on the computer with the recovery disc is the drive and enter setup. It should say something like press F9 or F10 for Setup. Look through the menus for "Boot Order", make sure your CD/DVD drive is above hard drive. Save the changes and reboot, you should get a message "Press any key to boot to disc" or something similar, do so, and follow the prompts to re-install windows.
Testimonial: "Sound good. Thanks, But how will I know if the hard drive has failed?"
You could use a DFT program to test the drive such as SeaToolshttp://www.seagate.com/support/downloads...
If your particular eMachines model didn't come with recovery media or you just misplaced the disc, you don't want to be caught without a means to restore the operating system.
It's all too easy to accidentally download a virus or experience any number of problems that make your computer unstable.
However, there is an option for restoring your computer without the original recovery disc by using the pre-installed recovery software.
Use an external memory device such as a DVD, flash drive or external hard drive to back up the data you need to save from your eMachines computer.
Any data that isn't saved to an external source will be erased when the computer is restored to factory settings.
Remove any discs that are in the optical drive and unplug the computer's peripheral devices, such as an Ethernet cable or scanner.
Do not disconnect the keyboard, mouse or monitor.
Click the Windows "Start" menu and choose "All Programs."
Navigate to "eMachines" and choose "eMachines Recovery Management." Click the "Restore" tab.
Click "Password Settings" if you have not already set a recovery password. Type a new password in the text box and click "OK." Click "Restore System to Factory Default."
Type the recovery password and click "OK." Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process.
Select "Finish" and wait for the eMachines computer to restart.
Use the series of installation prompts that appear on the screen to create a new user account for your operating system, set the system date and time, and set up your internet settings.
hope this helps
Test the PSU if the units fan is not working the power supply unit is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
