Vehicle Parts & Accessories Logo
Posted on Jul 06, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sun roof Asc light blinks and I can't open my sun roof
Michael Green
Level 3:
  • Vehicle Part... Master 3,799 Answers
  • Posted on Jul 22, 2013
Michael Green
Level 3:
Answers
3799
Questions
0
Helped
599624
Points
10177
Make and model please! Incidentally, the ASC and sunroof are not connected. One is traction control (ASC).
2002 Chevy cavalier sun roof won't close, but opens normally.
need service get it?
the channel tracks are bad or broken or dirty.
clean out?
that is never strange, broken or thermally.
I hate sun roofs most are made with cheesy weak cheap plastic parts. that LOVE TO FAIL. my Jeep is a convertible; vastly better
google sun roof fails, and cry. (vast did)
and always fails (stuck open) when it rains, (murphy;s law)
sure in physics 101 google how materials expand hot.
icing too.fails (packed in ice)
even the car body can expand hot,and does.
google material thermodynamic expansion and contraction.
https://en.wikipedia.org/wiki/Thermal_expansion
Problemas con las luces cortas y el sun roof no funcionan
english please.
google says
The short traceras lights and sun roof do not work like this can resolber fabor if anyone can help
google fails. and me worse.
sun roof.:
blown fuse
bad wiring or switch to roof
or jammed roof mechanism.
or bad motor.
get the FSM on car, read the sections on each failure/
the tests are there.
2answers
Can't start truck after battery change or unlock the doors
turn ignition switch on position for 20 seconds then try to lock and unlock doors.if you have sun roof open sun roof fully then close sun roof fully. then switch off ignition switch then try to start.
1helpful
Inalfa sun roof installed 3-29-04 in a Cad CTS 2004--will slide open but will not close all the way--any ideas on what to check?
may have slipped on the track mechanism and needs adjusted custom car shop may help with this..good luck..
7helpful
5answers
ASC Sunroof needs to be programmed
hold the vent button until the roof has "tilted" completely, then hold the open button until the roof has opened completely. the light that reads ASC should now be green and your sunroof should operate normally.
7helpful
2answers
Can not open my mini cooper roof all the way
Have you checked the parcel shelf is seated properly as there are micro switches beneath it so the car knows it will not jam the roof as it is lowered?
6helpful
2004 Expedition Sun Roof Leaks
you have 2 drains in the front that go down the a pillars and dump near the fenders.
The rear usually go down the B pillar or C pillar and out thebottom near the rocker panel.
Blow them out from the top with compressed air and make sure you have air flow at the exits.. Open the roof to see drain holes in the four corners.
  • The roof opening panel leaks
  • Roof opening panel adjustment.
  • Front rail seal.
  • Drain tube attachment points.
  • Roof opening panel water trough and seal.
  • Roof opening panel drain hose.
  • Roof opening panel seal.
  • Roof opening panel.
1 is the drain hoses
1helpful
4answers
Sun roof will nt close cant find the rite fuse
check fuse F1.401, 30 amp in central junction box (in truck). Check your owner manual for fuse information.
Headliner must be removed to access motor.
Visual Inspection Chart Mechanical Electrical
  • Roof opening panel frame
  • Roof opening panel drain hoses
  • Roof opening panel lifter assemblies
  • Roof opening panel air deflector assembly
  • Roof opening panel shield
  • Battery junction box (BJB) fuse
  • Circuitry
  • Accessory delay relay
  • Roof opening panel switch
  • The roof opening panel does not open or close
  • Battery junction box (BJB) fuse.
  • Circuitry.
  • Roof opening panel switch.
  • Roof opening panel motor assembly.
  • Roof opening panel lifter assemblies.
  • The roof opening panel does not open or close — one direction only
  • Circuitry.
2helpful
2answers
05' lincoln navigator sunroof won't open and motor makes noise but nothing happens?
The motor is stripped out. The sun roof might be binding on the sun roof track and the motor is not strong enough to move the roof. I would first replace the sun roof motor if available seperately.
You mihgt have to get the complete assembly because of part availability
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
