I started a self-cleaning and decided after an hour it was taking to long so I cancelled the clean. The door is locked and it continues to beep and flash code F9. Tried to unplug the stove to see if it would reset but still having the same problem, continues to beep.
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$%^^%$
The lock on the self cleaning oven door will not close. The lock is in the lock position and I can not close the door.
