I reinserted the filter and followed instructions of pushing reset button 5 times for 10 seconds but light will not reset to green. Is this just an indicator system problem or something I need to be concerned about? I have replaced filters 5-6 times and never had this problem. The water system seems to work ok.
How to reset the light is found in your models User Manual Click Here=> Whirlpool User Manuals
Sea Breeze
SOURCE: need to know where/how to
Hi, you will find the filter at the front of the appliance. If you look at where the two doors meet in the middle, right at the bottom of the appliance - you may have to open the door to see this properly there is a circular hole in the air vent grating with a handle. Turn this anti-clockwise - may be quite stiff but will go - and pull out old filter cartridge. reverse these instructions with new cartridge, hey presto, new filter installed.
Hope this helped
Alex
SOURCE: The light in my model ED5VHEXVB03 says I should
Whirlpool has two different style filters these vidoes will show you to replace each different style
http://www.youtube.com/watch?v=CPZgNYxFjjs
http://www.youtube.com/watch?v=lTVfbVkEINI
Hi
Find the indication light, located at the top of the Whirlpool
refrigerator just inside the door. This tells you when to change your water
filter. A green light indicates the filter is good and a red light indicates
you need to change the filter.
Find the filter knob. It is usually located at the base of the
refrigerator in the kick plate or grill.
Turn the knob a quarter turn to the left to unlock the filter.
Pull out and remove the old filter.
Add a new filter and push in. Turn the filter a quarter turn to
the right to secure it in place.
Reset your filter indication light inside the refrigerator. Press
down and release the switch five times within 10 seconds. The filter indication
light should then turn green.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
