1986 ford thunderbird fuel reset button
Ford generally put the Impact Reset switch, which turns off the fuel pump upon impact, back in the trunk over the wheel on the drivers side or within that area.
You just push the switch to reset. This is only for Impact related incidents though, and I'm not aware of any other switch designed just to reset the fuel pump or system except as added with anti-theft systems.
If you pump is not working, you may want to start with testing voltage to the pump itself and work backwards to the ignition and sensors.
