Cant find headphone socket for rosen in-car dvd player
I have a rosen in-car dvd player and cant find thee headphone socket for it,it says on the screen,headphone sound only,but cant find anywhere to plug them in????
rosen navigation my Rosen screen froze and the whole system does not work after that. Now it stays on the same screen and does not function no matter which button I press. What should I do?rosen navigation my Rosen screen froze and the whole system does not work after that. Now it stays on the same screen and does not function no matter which button I press. What should I do?
You can't post conmments that contain an email address.
Re: cant find headphone socket for rosen in-car dvd...
As far as i know, all Rosen in-car dvd players come with IR (infra-red) headphones so the sound is transmitted that way rather than using a lead from the headphones to the unit, therfore no sockets are neccessary!
Hope this helps....
Sounds like either that dvd player is on a different channel. Look for a channel switch on the headphones and also check the on screen menu to see what channel it is set to.
there is an addendum in the owners manual of ours on page two saying only with VWs the A7 is not configured to provide speaker sound through the vehicle speakers. helpline number is 019332 732 331. We have a VW touran also and can't get it to work :(
The problem could be that the outputs in the stereo are faulted. Did you get a warranty when you bought the stereo?, if not you may want to take it to a repair shop and ask for a diaognosis.
Hello, Had the same problem with my Rosen Headphones (see my entry on the 20 Aug) Take the batteries out of them and leave them out for at least 24 hours, put the batteries back in and they should work OK. I think the problem with my ones were that I did not use them for a few months but left the batteries in. So when not in use I wont be leaving the batteries in. Please note they will turn themselves off if they don't receive any IR signal after 3 mins.
If it's a Rosen dvd player the dvd will need to be put in the unit itself & not the unit in the dashboard! The dvd player mounted in the head ligning is a seperate unit from the stereo system fitted in your dashboard!
Sounds to me like you are putting a dvd into the dashboard stereo system which will play any audio through the car speakers...
Put a dvd into the Rosen unit itself & i am sure you will get a picture on the drop down screen! Remember that as far as i know all Rosen dvd players transmit the sound from the dvd to infra red headphones that should be included! Remember to check the batteries if you still can't hear any sound as they run down quick if the headphones are left on!
Hi, The A7 has 3 sound modes. With the unit on press the speaker button and on the screen it will say either "Headphone sound only" or "Speaker sound enabled". Pressing the speaker button will toggle these modes back and forth. If you don't hear any sound when it says "Speaker sound enabled " it may be that it was wired using the FM Modulator, which means it uses the car speakers. For them to work, turn on your radio and tune it to 87.9 or 88.3. Good Luck!
You will probably find that the interior of your car is too cold. This equipment is designed to operate between temperatures of 0C and 50C. Allow the interior of the car to warm up and try again.
I noticed my Rosen player had an antennae wire for the headphones on the top of the player. You could check to make sure the antennae wire is connected.
