Orange israel
Go to MenuSettingsConfigurationPersonal Configuration SettingsOption->Add New.
Enter details for the following parameters:
Connection name: myGlobe GPRS
Homepage: http://www.globe.com.ph/globe.asp
Access Point Name: www.globe.com.ph
Username: <blank>
Password: <blank>
Used preferred access point:<No>
Access point settings:
Proxy: Enable
Proxy address: 203.177.42.214
Proxy Port: 8080
Data bearer: Packet Data
Bearer Settings
Packet data access point: www.globe.com.ph
Authentication type: Normal
Username: <none>
Password: <none>
for mms :
Go to MenuSettingsConfiguration SettingsPersonal Configuration SettingsAdd new.
Account name: myGlobe MMS
Server Address: http://192.40.100.22:10021/mmsc
Use preferred access point: No
Proxy: Enable
Proxy address: 192.40.100.20
Proxy port: 8080
Bearer Settings
Packet data access point: mms.globe.com.ph
Authentication Type: Normal
Username: none
Password: none
Title: MMS settings
For Hotlink GPRS Activation
Press *133# to activate your Gprs & MMS
For the setting
1. SMS "GPRS "BRAND" "MODEL" and sent to 22333 example "gprs nokia n70"
2. SMS "MMS "BRAND" "MODEL" and sent to 22333 example "mms nokia n70"
Manual WAP Settings
? On Desk, tab Control Panel -> Internet setup. (or similar)
? Tab New access pt. and tab No, then tab Next and key in the following:
Connection name: Maxis GPRS / Maxis 3G
Data bearer: GPRS
? Tab Next
Network type: IPv4
Auto-retrieve access point: (Unchecked)
Access point: net / unet
? Tab Next and key in the following.
Prompt password at every login: (Unchecked)
Username: maxis
Password: wap
? Tab Next then tab Finish and OK to complete the setup.
? Homepage: http://wap.maxis.com.my/wml/index.wml
? Session Mode: Permanent
? IP adress: 202.075.133.049
? Login Type: Automatic,
? Authentication Type: Normal
MMS Settings
