Mi tv no enciende, no reacciona en nada.
If the TV is fully out, you have to start checking its main power regulator section. As you know, without proper power supply, the TV won't work well. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.If you wish to get some support to Sony Service, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option. The site has tranlation option, which can be selected from its right side bar, that pop ups.
SOURCE: bunas dias , mi problema
Que tal yo tambien tengo el mismo problema con mi tv insignia de 32¨ , mi problema es que la tv insignia no enciende a pesar de que la fuente genera todos los voltajes, al dar power el led cambia de rojo a azul pero no hace nada, como dije todos los voltajes estan presentes a la salida de la fuente, cambie todos los filtros de la fuente pero nada, gracias por su ayuda.
mi corre es [email protected]
SOURCE: Buenas noches, tengo una hitachi
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
SOURCE: tengo problema con un tv L32HD31 no enciende para
Hi, Your TV is on standby and does not switch on due to errors for fault within. This can be a protection cut off or a normal failure.
You need to start from checking the power supply unit which is a SMPS unit.
If there is ouput from the power supply the fault can be failure of the drive circuit , the light stays in orange due to this factor.
If you are equipped you can open to look for damaged capacitor or open resistors . Use a multimeter to check for possible short in the +B circuit so as to confirm by isolating the circuit for the power indicator to switch to green.
Segun el manual servicio, esta falla se debe a la placa A que esta defectuosa. Antes de reemplazar la placa A, seria necesario de revisar los voltages de la fuente de alimentacion.
Si necesitas el manual de servicio, te lo puedo mandar via email.
Tengo una placa A disponible si estas interesado.
