Stellar Phoenix Windows Data Recovery recover deleted data from the Windows Recycle Bin, restore lost data, even if the partition is formatted or deleted, restore data from a corrupted hard drive, virus infection, unexpected system shutdown or software failure. It supports IDE, SATA, SCSI, USB hard disk, memory card, USB flash drive, CD/DVD, Blue-Ray Disk and iPod.
SOURCE: Jumper settings for a Maxtor hard drive, Model 87000D8
This looks like documentation from the time but it is not from a manufacturer's site.
http://stason.org/TULARC/pc/hard-drives-hdd/maxtor/87000D8-DIAMOND-MAX-7000MB-3-5-SL-ATA3.html
near bottom of page.
SOURCE: recover data from a non responsive LaCie F.A. Porsche Hard Drive
Does your drive make any unusual sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
If yes then you got a problem - it's something mechanical with the heads and it's not something you can fix by yourself.
If it sounds normal or doesn't spin up at all - try to connect it to another computer and if still no go - remove the internal drive from enclosure and connect directly to PC via SATA port.
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
SOURCE: my external hard drive is corrupt, i want my data back.
Dear,
Data can be recover but the drive must be accessible by OS. As you write windows vista says drive is not accessible and that the disk structure is corrupted and unreadable.Do one thing try the same drive at another PC. If it run on that PC copy the data to that PC. Now format the drive and paste the same data back to your drive. But, if same thing happend then there are chances of fault in the driveand for this you shuld visit to the service cetre but, they are not responsible for the data.
Thanks & regards,
Rakesh Kumar
SOURCE: how to recover data from corrupted hard drive?
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files.
http://www.asoftech.com/articles/free-data-recovery-download.html
