I use internet via bluetooth and phone as modem but speed is slow comparing to the broadband connection.why? How can I increase its speed while using the phone as modem?
Internet broadband connection is much more faster because it is directly connected via physical connection from the modem (typical setup for home use). But now a days wireless internet can now compete with DSL thru a 3G/HSPDA network. In our country we can have a maximum bandwidth of 2.5Mbps using 3G wireless network.
Answer:
Yes you can speed up your connection using your phone as a modem but you need to consider some aspects.
What happen to you most likely is that your are connected using only a GPRS/EDGE. This is equivalent to a dial-up with maximum of 56kbps transfer rate. There is a great gap between the two if you compare it.
I already tested mine with maximum receive/downlink of 2,501 Kbps. I was really amazed.
Hope this things help you. If it does, please rate me.
regards,
-engrkoiled-
U may try the Google search.Many of online tips available for the increse the internet.And u check the internet speed with the site
ipdetails
Basically:
Broadband = Fast Internet
Phone as Modem = Slow Internet
If you are on a 3G network, you can tweak some settings and get around 1.5MB down. Until the newer technology is implemented to give your phone more bandwidth that will have to do. I would use the phone as modem as a last resort only.
Well Said Frank, There is also signal problem with the connected network.
