To be able to scan to pc you have to have the scan file utility set up on the pc
the scan file utility is on the CD that came with the copier.
you can Google the file if need be
when you have loaded the file you will need to go to
start, all programs,kyocera (scanner file utility and open it
once in configuration you will need to do the following
select setup
on the top you will see a box, type in 001
file destination, you should hit the box next to this and select kyocera/scan file
press ok and you are done
Next
get the ip address of the scanner, you will find this in scanner default when you have pressed thecounter/system menu button
get back into normal copy mode
on your web browser type the scanner ip into the address bar and you will get into the scanner command center
press the start icon bottom left of your desktop, go to run and type in cmd
once in dos mode type in ipconfig, this will give tou the destination address for your scans
now back to the command center, select sender info (left side menu) and type in kyocera after selecting 001 (blue numbers) and submit
then go to destination setup (scan to pc) and under 001 (blue) enter the relavent info, the address will be your pc's ip address.
say no to all password requests
and submit
very important now is to close the browser as you cannot scan when the command center is open
please take the time to rate this fix
