How do i fix my phone, it wont turn on and everything appears to be fine even the battery is fully charged but the phone wont turn on? Is it fixable?
SOURCE: D900 - Wont turn on !
CHANGE THE CHARGE CONTROL IC,LOCATED BY THE BTEMP BATERY SAME LIKE D500
SOURCE: my phone keeps turning and off and at the moment
ur mobile's software is bursted and u need to reinstall it at any nearest samsung store
Testimonial: "thanks il just go to the phone shop when i can meanwhile il use another phone"
SOURCE: my phone says "battery type non supported"
take the battery out, blow on all the ediges, as well blow in where the phone was sitting in the phone. just make sure the battery is getting a good connection with the phone. snap the back of the phone back on and make sure its on the way on.
if you still have issues its possible your battery has gone bad and you will need to get a new one.
SOURCE: Phone won't hold charge at all
it's because of water damage, there should be a little square && it should be WHITE, most likely if your having this problem its because the little square is RED.
buy a new phone.
SOURCE: I accidently swam with my cell phone in my pocket.
your gone 2 have 2 take the sim out dry air dry and get a new phone
