Nikon N80 35mm SLR Camera Logo
Posted on Aug 25, 2007
F -- displays when I turn camera on, and can't shoot
When I turn on my camera, F - - flashes a few times in the screen and I cannot take pictures. Have not located my manual yet. Any ideas?
  • whatisvalid Aug 26, 2007
    Thank you! I did locate my manual and the error code signals a non-CPU lens attached, or that the lens is not attached...my lens was not fully attached.
Anonymous
Level 1:
  • Contributor 42 Answers
  • Posted on Aug 25, 2007
Anonymous
Contributor
Level 1:
Answers
42
Questions
0
Helped
53915
Points
53
I suppose you had turned the Mode-dial to P, S or A but did not set the aperture to the smallest, i.e. the largest value. This camera cannot control the diaphragm automatically if you do not do what I said before.
2answers
When I take a photo the display screen flashes
This is a normal phoneme. The camera wants to show you where the picture is overblown. In these parts you can't see any details, because in JPG it will show it one colour. Most of the time this will be complete white.
When you are shooting in RAW (NEF in your Nikon) most of the time you still get detail, when you work in one of the RAW editors, like Photoshop, DxO and other picture edtors.
2helpful
LCD Display is Black
the image in the LCD monitor will darken in strong sunlight or bright light. This is normal occurrrence in device CCDs and does not contitute a malfunction. This image will not be recoded when shooting still photos, but it will be recorded wihen shooting movies.Read you owner manual and adjust the MENU, according with your o. manual.Otherwise you must go the repair shop
God bless you
3helpful
Canon EOS 450D Can only get the Shooting Setting Screen no image
In picture taking mode, press the "set" button for "live view".
Fuji camera screen does not display picture even when screen is turned on when taking picture. but screen shows picture when you view pictures already taken
Hi dear, you need to see the manual (http://www.retrevo.com/support/FujiFilm-S700-Digital-Cameras-manual/id/2488ag805/t/2/)
Some camera only use viewfinder to shoot photo,The LCD is for setup and display photo only.Because it's off it will save a lot of battery power so that you can shoot more photos.Check it out in the manual.Have FUN!
1helpful
Battery level don't show on display.
hi friend,
follow these steps
  1. Turn off your LCD display screen. I know this is hard—who likes shoving their face against the camera to compose a shot through the little viewfinder? But the LCD screen single-handed-ly drains a lot of power.
  2. Minimize the picture preview to the least amount of time possible—usually one second. This uses less LCD screen time, thus less power.
  3. Dim the brightness on your LCD screen. A dimmer display extends battery life by consuming less power to light the screen. This might make the display harder to see, but usually only in direct sunlight.
  4. Set the power saver to the least amount of time. Power saver lets your digital camera “sleep” when not in use, but doesn’t shut it down entirely. To “wake up” your digital camera, simply click the shutter button.
  5. Use your zoom as little as possible. The motor that moves the lens uses power. This also goes for repeatedly turning your digital camera on and off if it has an extend able lens.
  6. Turn off the continuous focus. Again, constantly using motors and electronics to ready your shot drastically minimizes battery life.
  7. Don’t push the shutter button half-way down until you’re ready to shoot. Pushing the shutter button (constantly resetting and refocusing) will drain battery life.
  8. Use the flash only when necessary. Your digital camera’s “auto flash” option should take care of this, but make sure your flash isn’t going off in broad daylight.
  9. Don’t delete pictures from your digital camera unless necessary. This consumes power. Wait until you download the pictures to your computer before deleting.
  10. This one’s basic, but charge your battery often. Lithium ion batteries, which most digital cameras use, don’t have “battery memory” like older alkaline. In fact, lithium ions work better and last longer if charged completely and regularly.
thank u for using fixya
regards,
sivaranjini
1helpful
I get a warning which says *Battery Exhausted*. I've replaced them but still get the warning.. Any idea whats wrong?
earlier i posted solution in similary problem. maybe help you this.
solution is good batteries, Ni-Mh or Lithium, rechargeable only not alkaline. but...problem is how long you watch pictures on lcd display or how much is flash in use. if always by shooting pics used flash that means that you can with best batteries 30, 20 or less pics shooted. and of course, if you connect camera with pc, how long is cam on? just transfer pics on pc and turn the camera off. the best solution is use the card reader for pics transfering.
if is flash off, it's possible to shot 120-150 pics with Ni-Mh. with lithium i don't know, maybe 500 pics. don't use camera lcd for analysing pics it's just there for short preview.
with alkaline batt., very low quality, i shot 30 pics without flash.
i shot also very good pics at night without flash. nikon coolpix L15 can do that but you must have more praxis. alkaline batteries shooting!
after 3 pictures on display is message: warning! the battery is exhausted. what you can do? turn the camera off. wait about 10 minutes. turn the camera on, you can shot 3 or 5 pictures and than turn your camera off again.
you can repeat this few times and you be lucky if you 30 pics captured:)
REMEMBER: all this goes without camera flash!!!
flash and every zooming use more battery power! and that was all magic:).
Camera auto focuses, shoots but the view screen is black
Check the playback menu that the review time has not been set to OFF. This will stop any pictures displaying on the back of the camera when taking them!
I leave mine at 2 secs which is long enough to quickly review and keeps the battery life up. If I need to review for longer, just use playback.
The flash won't come on if you have the camera in any of the creative modes (i.e. A-DEP, M, AV, TV or P). You can manually use it by pressing the flash button just above the lens release button on the front of the camera.
2helpful
2answers
Camera not taking pictures
The camera may be trying to tell you that your flash is turned off in Auto mode, but to get a proper exposure you will need the flash turned on. Try turning the flash on and see if that works.
Hope this helps!
2answers
Whitebalanc; red cast over pictures
Greetings...
The red or orange cast comes from a warm light source since you have the auto white blance off...
Got to your menu and turn the auto white blance back on and then try taking the same picture under the same lighting and see if that corrects your problem...
Ed
Tech support
Hi, there is a very easy soln. to your problem.
When the camera is in shooting mode, just click the multi-selector( the round thing surrounding the OK key). the flash menu will be displayed in the screen. Either choose the auto flash(no.1) or anytimeflash(no.4) mode. the blinking hand will be gone and you will once again have superb photos. relax and enjoy.
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
