SOURCE: PIP for Sony KV-27XBR45 television trouble shooting
If you have the original remote for this TV on the pip menu (left side slider on remote all the way up) there is a pip off button. If you unplug the unit long enough it should go back to normal. If you go into demo mode and then exit mode you will again be out of the pip. With out the original remote you cannot easily turn pip off.
SOURCE: pip is stuck and i don't even have a pip button on my remote!
The problem was solved by using the TWC cable remote control and selecting "TV" on the top and the press the big blue "Select" button. DO not forget to put the remote back into "CBL" mode. Apparently this is a hidden feature, which works even on TVs, which officially do not support PIP. I works only with the one tuner, video 2 and video 3 but not video 1.
SOURCE: TRINITRON XBR/ADVANCED 2 TUNER PIP Model KV32XBR45 Manufactured 1995
WELL I need some more information so I be able to assist you, first , it could be that the REMOTE CONTROL is not that came with the TV originally , and since all SONY remote control have the same basic codes ,it could be that the remote doesnt have this specific feature. I did some research base on the model of this TV , the original remote control model num. is RM-Y127 and
not RM-Y153 , maybe thats why it doesnt have the PIP feature. hope this info been helpful
SOURCE: PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
SOURCE: I have a sony trinitron XBR 32 inch... The pip was
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
