I have a compaq presario 1200 laptop that used to come on now and then when plugged to outlet i'm sure the battery is bad but now it won't power at all
mine it powers sometimes and it works fine through out the task , but once i turn it off , it won't power up again.mine it powers sometimes and it works fine through out the task , but once i turn it off , it won't power up again.
You can't post conmments that contain an email address.
If you have another Compaq Presario CQ60-220US swap the power adapters and see what happens.
Make sure that the battery is firmly seated. -You may also want to try to turn it on with out the battery with only the power adapter connected. -If it works without the battery I suggest to contact the manufacture for a replacement or order a new battery.
First thing to try is to remove the power cable then remove the battery. Then using just the power cable try to reboot. Second would make sure the brick on you power cord is pushed in all the way and that the green light is on. Third plug it into a different wall outlet. Directly into the wall. Please get back to me if this dosen't work.
I had a similar issue with the Armada M700 from Compaq. Never did figure it out exactly. But I do know this. When you unplug the power chord and take out the battery and plug the power chord back in while the battery is out usually for some reason it turned on allowing me to replace the battery which would then begin charging. Your problem interests me because I can really relate!
Please first make sure that your adaptor is working.
Try to remove the battery and connect your laptop to the adaptor. Swith on. If nothing chages, then there is good chance that you have a motherboard related problem.
