Garden Logo
Posted on Mar 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New battery re-charged but still wont fire
Will try to turn over until battery is flat
Cleverer2
Level 2:
  • Expert 298 Answers
  • Posted on Mar 26, 2009
Cleverer2
Expert
Level 2:
Answers
298
Questions
0
Helped
98898
Points
775
Check for spark
If yes, it is getting FIRE, just needs AIR and FUEL
Give it a 5-second shot or two of Starting Fluid (Ether) through the Air intake (filter) and try to start
Does it kick and run really fast and then stop?
If not, pull the plug, clean and check for GAP of 2-3 matchbook covers. Retry. Does it run (or try to)?
If it does, Now we have to look at Clogged air or fuel filter or water in line(s)
Remove air filter. Try ether again. If it starts and runs, replace or clean air filter. Done!
If not... Replace AIR filter and Drain fuel into metal or Glass jug, take off fuel filter, open and drain fuel bowl. Replace fuel filter, refill tank, prime, give it a shot of ether and try again. If it runs, Done!
If it still will not stay running, but you can coax it by giving it a blast every 5-10sec, it could be linkage, stuck choke, throttle plate or jets. Give carb a good cleaning, check throttle plate (in carb throat between it and Air Cleaner) and.check Choke. Try again.
If it still will not run, take to mower mechanic.
2answers
Batteries go flat if left in camera
your title says camera ? but your post is in pride mobility ? but this will apply for any rechargeable batteries. the batteries could be at the end of there life ( they only charge so many times ) but cold and other things can drain them. heres a fix to try and get the full charge to stay full. you might have to do it a few times. charge batteries over night untill fully charged,prop the scooter up and jam the throttle on and just let it run flat ( anything else with full charge do the same.power on and let them run flat ) once there flat recharge again but drain the battery so it wont even light the lights.try it to see if the next charge holds ? if not try the same thing again. this is called calibrating..you might find after the first try it will hold half of its charge but will get better the more time you calibrate it. if that dose not work you will need new batteries. also try leaving them out of the item not in use to see if they drain on there own,this could give you a clue as to something being left on when there inside ? hope this helps
1helpful
2answers
Kindle fire will not charge-got a new charger and it still will not charge- does it need anew battery and how do I do that?
The Kindle touch and the Kindle FIre are great devices for your reading needs. However, there are times when it becomes unresponsive and freezes on you. Amazon says it is because the battery isn't charged properly or does not have enough power on it. It is advisable to charge your battery first before trying to reset the Kindle touch/Fire. If theKindle still has issues, then try the steps below on how to reset your Kindle touch/fire. Please note that you may lose your data during the reset process, make sure you have made a backup of your files before proceding.
  • Hard and soft reset
    Make sure the Kindle is turned ON.
  • Press the Power button for 20-30 seconds until it turns OFF.
  • Wait for it to reboot, if it doesn't press the power button to turn it ON.
  • Your kindle should be back to a responsive state.
  • this might help you.
Hyosung ms3 250 battery fully charged engine turns over wont fire up also new spark plug fitted
has spark? has fuel going to carb? if you smell gas from the muffler or carb then it not burning check for spark pull plug touch away from the hole so you don't ignite the vapors on the engine look for a great blue red spark
2helpful
4answers
The kindle won't turn on
It is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't turn on at all this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
3helpful
2answers
`kindle fire
Sounds like your power cord is dead and that it's not charging. If it's new bring it back to the store you bought it from and get a new one.
Dose the vivitar vivicam 8025 have charge befoe u can trun it on it brand new and wont trun on can u help me please
most camera are sold with "flat batterys" in them (its a fire hazard thing) so you need to fully recharge the batterys before use or the camera will just turn its self off,,,look at the hand book for charge times? dont try using it on half charged batterys you only kill off the battery that way,,,
I have a ZX9R 97 B4 and on the whole she?s a great bike all be it for one problem ? starting. some days she starts no problems at all other days nothing ! in fact I?ve found that when it wont start I...
My old 84 GPZ was similar,
sometimes start straight away
sometime spin until the battery was flat.
occasionaly start just as you let the start button go.
roll start straight away.
I believe the battery was putting out enough amps to spin the bike over but the voltage was down to 11.5 volts, this wasnt enough for the electronic ignition which needed nearly 12v to fire.
The reason it would start as the button was released was a slight voltage rise while the engine was still turning and it would fire.
I cant explain why it wont start after charging
A new battery solved it, plus I ran some battery conditioned called INOX in the electrolyte.
I'm in Australia, not sure if you can get this product .
Your bike sounds like a similar problem, hope this helps
May 20, 2010 • Motorcycles
Top Garden Experts
Jay Finke
Jay Finke
john h
