Posted on Mar 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changing the belt on a Technics SL-3 (Linear tracking) turntable
How do I change the belt
Anonymous
Level 2:
  • Expert 515 Answers
  • Posted on Mar 27, 2009
Anonymous
Expert
Level 2:
Answers
515
Questions
0
Helped
292952
Points
647
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Technics SL-J33 turntable high speed problem. Setting on 33rpm or 45rpm makes no difference, still runs at approx. 60rpm.
The drive ic is shorted or there is a small transistor that is bad not having the unit on a bench is is hard to track down the part. But it is a easy fix if you find the service manual and can do soldering the manual will tell you where to find the part that is making to run away! The main thing is to find the parts is you find the # on the parts I can or you can look up those parts. Good luck.
Technics SL-1210M5G Turntable
1 If it's a belt turntable - the belt slips off.
2 A power supply problem.
3 A faulty motor.
Owners manual for SL-L3 turntable
Two Speed Direct Drive Fully Automatic Turntable with linear tracking ... Technics SL-L3 / SLL3 owners manual, service manuals and schematics are for ... www.vinylengine.com/library/technics/sl-l3.shtml
hope this will be of help
1helpful
Where can I purchase a new rubber belt to drive my Servo Automatic turntable SL-B210 Ths is not an electronic belt
Here is a link for Technics Turntable replacement belts...just scroll way down the page for your SL-B210 belt listing $10.00. Hopes this helps.
http://www.turntablebasics.com/belts/technics.html
1helpful
Suggested lubricant for Technic SL-5 linear tracking tonearm
technics used special grease for lots of their products, any good quality grease will do but use sparingly
How do I change belt on a Technics linear SL -H350 turntable
http://www.archive.org/details/Turntable_Belt_Installation
above video should help. if your platter is "stuck" then call them for tips. also make sure it does NOT say "direct drive" on the front of the unit.
presuming you are talking about the SL-H350 as in the body not the SL-DZ1200 as in the title
6helpful
3answers
Technics SL-J1 turntable drive belt
Hello Cliff,
You will need 2 belts, if the turntable belt is gone the other is not far behind . One for the turntable size 23.6 inch by .188 and one for the tracking motor that is in the top cover part, is a 3.0 inch by .046 belt. best place to get them is at kenselectronics.com part numbers 1407-201 and AV-SBS3.0 if you have been checking around you will see other sizes, I have a SL-J1 and have used these and they work perfectly.
Tony
Problem with technics SL-L20 linear tracking turntable
Not sure what your question is? Linear tracking turntables also have an assortment of gears and pulleys which make it function correctly. Sometimes the drive belt will break, other times, the gears will crack. You will have to open her up, and take a look inside to see if there are any components which are damaged. There may also be grease applied to the gears, which might also be preventing it from moving properly.
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
Technics sl-ql 15 linear tracking T/Table
Parts are discontinued for these models. You need what's called a P-Mount cartridge screw. Try the following company:
www.lpgear.com
- DAVIS
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.1200s.com
1helpful
2answers
Record player belt
Scott, the belt wraps around the bottom of the turntable platter, then put the platter back on your turntable, and you'll have to pinch back a section of the belt and wrap around the brass motor spindle. That's pretty much it!
Good luck.
- OPTiC
TWEAK A/V LAB
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
