Thanks for the quick response. That's the first place I looked for help, but the answers were not specific to my problem. I saw one person recommended replacing the scanner assembly, but considering the time, effort, and cost, I will replace it with another all in one machine. It still prints fine, so I can give it away as a printer.Thanks for the quick response. That's the first place I looked for help, but the answers were not specific to my problem. I saw one person recommended replacing the scanner assembly, but considering the time, effort, and cost, I will replace it with another all in one machine. It still prints fine, so I can give it away as a printer.
You can't post conmments that contain an email address.
https://support.hp.com > ca-en > document
When a 30.03.23 Error Alignment Calibration Failure appears on the control panel, it indicates there is an issue calibrating the scanner.
Scanner Failure usually results in Hardware Failure. However there is one step you can try. Try connecting the printer directly to wall outlet or any other power outlet and the issue should be resolved.
he HP All-in-One product displays one of the following error messages on the control panel when scanning or copying:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
Additionally, the scanner bulb might not turn on during scanning.ry the following
solutions in the order presented to resolve the issue. When one of the
solutions resolves the issue, there is no need to continue
troubleshooting.Solution one: Check the scanner lightFollow these steps to check the scanner light by making a color copy of any document.
Load plain white, unused, letter size paper in the paper tray.
Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
Make a color copy.
When
the product starts to scan the document to copy, slightly lift the
scanner lid to see if the scanner light turns on. It is not necessary to
lift the lid completely CAUTION:Do not look directly at the scanner light.The scanner light should be visible under the scanner glass to the right or left.Figure 1: Scanner light visible underneath the glass 1 - Area where scanner light is visible2 - Scanner glass
If the scanner light does not turn on
when the scanner mechanism moves across the scanner bed, continue to the solution to reset the product.
If the scanner light turns on
, continue with the next solution.
Solution two: Check the power connectionFollow these steps to troubleshoot the power connection.
Press the Power button (
) to turn off the product.
Unplug
the product power cord from any surge protector, extension cord, or
power strip, and then connect the power cord directly to a wall outlet.
) to turn on the product.
Try again to make a color copy.
If these steps resolved the issue
, you do not need to continue troubleshooting.NOTE:If
the product works properly when plugged directly into a wall outlet
rather than a power strip or surge suppressor, the power strip or surge
suppressor might not allow enough voltage for the product to work
properly.
If the issue persists
, continue with these steps.
) to turn off the product, disconnect the power cord from the wall outlet, and then reconnect the power cord to a different
wall outlet.
, continue to the next solution.
Solution three: Reset the productFollow these steps to reset the product.
) to turn off the product.NOTE:The product might not turn off after pressing the Power button. Continue to the next step regardless.
Disconnect the power cord from the rear of the product.
Unplug the power cord from the electrical outlet.
Wait 30 seconds.
Replug the power cord into the electrical outlet.
Reconnect the power cord to the rear of the product.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on Scanner System Failure Scanner failed, cannot make copies or fax Scanner failure. Unable to scan, copy, or send a fax Scanner failure, cycle power
You may want to try following these steps: 1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product. 2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer. 3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Make a color copy.
When the product starts to scan the document to copy, slightly lift the scanner lid to see if the scanner light turns on. It is not necessary to lift the lid completely.
Solution two: Check the power connection Follow these steps to troubleshoot the power connection.
Press the Power button to turn off the product.
Unplug the product power cord from any surge protector, extension cord, or power strip, and then connect the power cord directly to a wall outlet.
Press the Power button to turn on the product.
Press the Power button to turn off the product, disconnect the power cord from the wall outlet, and then reconnect the power cord to a different wall outlet.
Try again to make a color copy.If these steps resolved the issue , you do not need to continue troubleshooting.If the issue persists we have to reset the printer. Doing reset in the beginning stage is not recommended. Reply me back and i will provide the reset step instruction.
Try to reinstall the driver Try to check HP if there is a latest driver to download. Try to plug it to another USB port. Try to plug it to another computer. If it still has the same issue, then it might be that your scanner is faulty.
The message
'Scanner failure'
displays on the control panel of the product. This error can occur when the product is warming up after
you turn it on. Please visit the below mentioned link.
