Car Audio & Video Logo
Posted on Mar 26, 2009
CD stuck in my car CD player and cant eject it when i hit the ej
CD stuck in my CD player in my car and will not eject when i hit the eject buttom
Anonymous
Level 1:
Problem Solver:
  • Contributor 3 Answers
  • Posted on Mar 26, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
2121
Points
10
It may be you have a paper label on the cd most car cd player won,t handel paper lables not enuf room as for getting it out try this get a light and see if you can see the cd if so take a pop sickle stick with a small amount of super glue on tip and be vary careful put the pss in to opening to the edge of cd let set for a few seconds then try pulling it out when pushing eject donot use but vary little super glue i have done this on some cd player
How do i eject and play cd's.
Look for a button that says ( eject ) on it, sometimes it maybe shortened and may say something like ( EJ ) or may have the eject symbol, which looks like this, found below.
I've had a sony cd player which has no eject button, I had to glide my finger from one side to other side, which ejected the cd.
Also the stereo manual is helpful, if the cd player is original and not aftermarket, the car owner's manual can help.
Original or aftermarket , product support line or their website can be a helpful.
Good luck, hope this helps you, answers your question and have a nice day.
b0a5e9ab-b66b-4283-bf59-3753ba66aebf.jpg 359699a2-5b97-4f4e-8dc9-e09bb799fa19.jpg
CD player "bad disc" CD stuck in
Use a plastic object to get under the disc while hitting eject. sounds like the gears are skipping or off.
If you need further help, reach me via phone at https://www.6ya.com/expert/chris_b82b45c59bcf133d
Ejection error for 2004 marquis cd player
How to fix my CD player when it says CD error when I put a CD in
How do i get my cd out its stuck when i push the eject button it dosent come out
A trick I've used several times is to hit the eject button and take another CD, put it in about 1/3 of the way, push down on the CD that's stuck inside while pulling forward, all of this while the deck is trying to eject will usually get a stubborn CD out.
My camry cant accept a CD ROM, what can I do? I am in love with music. Their is no CD Plate inside because when I hit eject botton, nothing comes out. Yet, my CD cant go in. It is as if something is...
It sounds like a gear is stuck that is making the CD not insert or eject. It is going locking the CD turntable causing the mark when you pull it out. You may have to remove the player and take it apart to see what the problem is. You may be able to fix it or replace it with a used one from a junk yard. Once these go bad they are hard to fix unless you have a service manual for the CD player.
Cds are stuck in the default cd player of 2001 Dodge Intrepid. How do I get them out?
The first step is turning the car off. Then before turning the key back on, push and hold the Eject button then turn the ignition on. If the CD fails to eject then you can use a old CD and try to insert it into the CD Player, just as it try's to take your second CD pull it out and hit the Eject button again. This will usually get a Dodge CD player to Eject.
If this fails then the CD player must be removed and a manual eject can be performed.
2helpful
2004 FORD F-150 CD EJECT ERR
I've had this happen once before..CDR's are a little bigger than regular cd's.Sometimes they wont let go at all..You either can undo the battery and then reconnect then it usually automatically ejects or you'll have to manually do it or you can pull the fuse and then put it back in and the same proceedure..
Iā€™m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
6helpful
1helpful
Cd in car player will NOT eject -any ideas ??
The only way to fix your problem is to have a radio repair shop take it apart. You cannot fix this on your own. Remove the radio or get a quote from a repair shop first. If you cannot find a repair shop , talk to the parts guys at you local ford dealer about sending it out for repair.
2helpful
Cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
