Check the pipes are not blocked and the drain is high enough. the pipe has to be up to about 3 feet then down into the drain. . the pipes sometimes get clogged with hair or stuff. if you take the back off be very carefull as there are things in the back of a washing machine that hold charge and you can get electric shock easily. if you do take the top and back off. spray the pump with WD40 it might be stuck. but be careful do not touch anything in the back.
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
