When we select format disk it shows that it is formatting, but then returns to format disk...it never actually formats the disk
SOURCE: Memory Card Formatting for Z740 - max memory?
Take the card back bad card. You can use a 512 card or better.
SOURCE: new memory card will not format
You are probably using a 4 gigabyte memory card and your camera will only support a 2 gigabyte card. Get the right card and it will format properly.
Larry
SOURCE: memory card requires formatting- I select
say yes before that download data recovery software and then recover it
SOURCE: kodak cx7530 camera refuses to
Your camera was not built to take the new SDHC cards. You can only use SD cards up to 2GB.
SOURCE: The camera repeatedly tells me
The DX6440 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use cards 2GB and smaller.
Testimonial: "Fixed It! What else can I say?"
