Husqvarna Huskystar 215 Sewing Machine Logo
A
Anonymous Posted on Jun 30, 2013
Manual download how to open cover?
I am trying to oil my white model 1405 machine I can't open the top to do it
You can download a manual for your machine:
Instruction Manuals
You probably need to open the left cover first, then look for a latch or something to release the top.
Singer sewing machine model 7005, dog feed is not working. Where is the lever to adjust the dog feed.
The Singer Imperial 7005 does not have a feed dog lever. Instead there is a feed dog cover that gets placed over the needle plate. To remove the cover, raise the needle and presser foot. Open the slide plate, then lift up the front edge (closest to the bobbin) of the cover. Then pull the feed dog cover away from the sewing machine.
See page 10 of the manual; it's page 12 of the PDF. The manual is available at the Singer manual search page: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/676_7005.pdf .
I hope this helps.
Model 2139. how do I open body covers for maintenance?
Consult your owner's manual. If you do not have one, here is where you can order one:
http://www.sewingpartsonline.com/instruction-manual-janome-2139n.aspx
Do not attempt to open your machine unless the manual instructs you to do so. Some newer computerized sewing machines require maintenance only in the bobbin area. Trying to open the cover in other areas could break it.
How to open the pfaff synchotronic 1229
Do you mean taking off the travel cover and flip open the cover? Lift the handle to get it straight up. Press the latch in the center of the top on the front of the cover and let the lid tilt forward as far as it will go. Lift off the carrying case cover (sides and back). Then press the latch again and flip the lid completely down.
The accessory box needs to be accessed by reaching under the detachable work surface and swinging to the left. Then swing the bobbin holder to the rear of the machine. Lift up the work surface and open the lid to the box.
VSM Group now owns this Pfaff line and has the manual available here: http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf/1fd5659e6f37141041256697003e64c0/1b4dc207a9ed3ce7852575fb006d2eb5?OpenDocument . The direct link to the manual is http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf/1fd5659e6f37141041256697003e64c0/1b4dc207a9ed3ce7852575fb006d2eb5/$FILE/Pfaff%201229%20Synchrotronic%20x%20.PDF . See page 1 (page 5 of the PDF) for pictures of opening the cover on the machine.
I hope this helps.
3helpful
Singer 2263 instruction manual does not show where to lubricate or how to adjust the hook which keep jamming
First make sure that the needle is fully up. Then you need to open the hinged front cover and unscrew the needle plate screws. Remove the bobbin. Brush out any lint now. Remove the bobbin case. Then snap the hook retaining arms outwards. Remove the hook cover and hook. Put no more than 2 drops of sewing machine oil on the the case (center right hand side). Then turn the hand wheel until the hook race is in the left position. Replace the hook and then the hook cover. Snap the hook retaining arms back into position. Replace the bobbin case and bobbin. Then replace the stitch plate.
Test the machine on a piece of waste fabric. If the hook keeps jamming, take the machine in for maintenance. The parts that may need to be replaced are the race or the shuttle hook. However without seeing the unit I do not know if there is not another problem. Some parts for the 2263 are available here: http://www.sewingpartsonline.com/singer-2263-sewing-machine-parts.aspx .
Singer has a second manual available with the oiling instructions for the 2263 here: http://www.singerco.com/uploads/download/1213_oiling-2263.pdf . See the diagrams on this page for where things line up. The rest of the instruction manual is also online here: http://www.singerco.com/uploads/download/1180_2263%28eng_spa_fre%29.pdf .
I hope this helps.
Manual 2263 sewing machine free
You can download this manual from the Singer website, link is http://www.singerco.com/accessories/instruction-manuals, type in your manual number only and click search, wait a bit for the screen to build and you'll see a red box with "Free download", click on this and again wait a while as the file is large. It will open as a PDF file, save to your PC and you can then print the document at your leisure and perhaps get it bound in hard covers to keep the manual close at hand.
I need the singer sewing machine model 5050 owners manual
You can download a free pdf file from the Singer Website, link is
http://www.singerco.com/accessories/instruction-manuals, type in the search field your model number "5050" and click "search", wait for the screen to build, it will take a few seconds but you should see a "free download" link to click, again wait for the pdf file to open up, then save it to your PC, print it out and bind it in covers if you can.
Hope this helps you out. Most Singer and White manuals are available on the Singer website.
Top Husqvarna Sewing Machines Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
