Air Tools & Compressors Logo
Posted on Mar 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont spray i turn the machine on and have it set on the green side choice. Blinking light wont change to solid color. Am I too impatient or is there something that i am missing?
Anonymous
Level 2:
  • Expert 104 Answers
  • Posted on May 24, 2009
Anonymous
Expert
Level 2:
Answers
104
Questions
0
Helped
62909
Points
195
Possible cause could be that the spraying medium is too thick try thinning a little [ try spraying water through it to see if it works ]
Dolce gusto krups infinissima red light
The blinking yellow-green and solid red light on a coffee machine typically indicate an error or problem with the machine. Without more specific information about the make and model of your coffee machine, it is difficult to say for sure what the problem is. However, here are some common issues that can cause a coffee machine to display these lights:
Blinking yellow-green light: This light may indicate that the machine is in a warm-up or preheat mode.
Solid red light: A solid red light can indicate several different problems, depending on the machine's model and brand. Some common causes of a solid red light include a low water level, a clogged or dirty brew head, or an issue with the machine's heating system.
It is recommended to check the user manual for your coffee machine to determine what the specific light sequence means and how to address the issue. If you don't have the manual, you may be able to find a copy online by searching for the make and model of your machine. If you are unable to resolve the problem, you may need to have the machine serviced by a professional.
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ...
www.fixya.com > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya
www.fixya.com > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
1helpful
My panasonic th-42pwd8uk tv wont power on. When I press power it clicks to turn on then clicks again and the screen never shows up. No red lights no blinking lights just a solid green light.
Check the capacitors and replace the power components. It is an easy fix if handy with soldering electronics. Tv Repairman may charge less than $100.00 bucks to fix it !
Good luck
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
3answers
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Samsung hln617w non power up
Most of the time when these sets won't turn off it's caused by the DMD but check the color wheel connectors first, especially the flat ribbon cable. Make sure it's in the connector in the correct direction, only has contacts on one side and make sure the ribbon is not torn.
Player frozen, green light on
i had my GFs mp3 player and it was flashing green light, not solid, but still was frozen and couldnt even bring it up on my computer after plugging in the USB cable. but i just tapped the reset button on top right side, and it stopped flashing and turned off. i turned it back on and started to play normally. not sure if it will be the same since the light situation is different, but the reset button worked for me. good luck
New Bulb Doesn't Light
color wheel or light engine,call for service and save your money.
Top Titan Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Titan Air Tool and Compressor Expert? Answer questions, earn points and help others
