Canon PIXMA MX310 All-In-One Printer Logo
Posted on Mar 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does the MX 310 work with Vista - Canon PIXMA MX310 All-In-One Printer
DLewis
Level 2:
Scholar:
  • Expert 73 Answers
  • Posted on Mar 26, 2009
DLewis
Expert
Level 2:
Scholar:
Answers
73
Questions
5
Helped
106872
Points
265
Looks like you will need to download a driver.
You'll need to know if you have Regular Vista or Vista 64-bit.
Here's how you can tell:
64-bit versions of Windows Vista are for computer users who have high-performance needs and are typically running a computer with 4 GB or more of Random Access Memory (RAM). The terms "32-bit" and "64-bit" refer to the way a computer's processor handles information. The 32-bit versions of the Windows operating system can only use up to 3 GB of memory.
The 64-bit versions of Windows can use more memory and help reduce time swapping processes in and out of memory by storing more of those processes in RAM rather than on the hard disk. This, in turn, can increase overall system and application performance, especially with applications optimized for 64-bit. For more details about 32-bit and 64-bit, see the Windows Help and How-to FAQ.
To find out what version of Windows Vista is installed on your computer:
  1. Click Start Does the MX 310 work with Vista - start.gif, click Control Panel, click System and Maintenance, and then click System.
  2. Under System, view the System type.
If you're running Windows XP:
  1. Click Start, click Control Panel, and then double-click System.
  2. On the General tab, view the System type.
Now you know your system type and can download the correct driver from this page:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=15603#DownloadDetailAct
Let me know if that works for you. Be sure to follow all the directions.
The canon 310 MX is not able to accept new ink cartridges error 6000
if you purchased a canon 310 mx and if it is new..contact the supplier about it.So that they can instruct you how to fix it..Good day
1helpful
MX-310 has fax's in memeory but keeps printing the first page of the first fax only. Screen says check paper size. When i push ok it only will print the first page over and over. How do I change it?
If your Canon MX-310 has been set up to print faxes as they are received, then what is actually in memory is a "received fax report". If you select a particular fax in this report, it will print the first page of the fax to remind you of the content.
Your Canon MX-310 will store fax documents in memory if:
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
1helpful
How do I scan a menu with a picture on it into word 2007. I have a Canon MX 310 printer?
Canon MX 310 have its own scanner program to develop any pictures. Using that program can scan a pictures. I know you install that already like Photo Suites or etc..
Putting into Word 2007 are only Insert File or Pictures to made by adding it.
Black and white printing on Canon MX 310
there is in adjusting the seal the printer bookmark, seal grayscal stile. Search for in adjustment before printing
5helpful
1helpful
Reset mx 310
This really worked with my MX 310:  http://www.fixya.com/support/t378057-reset_ink_levels_canon_mx310
2answers
Clicksmart 310 vista
i dont think logitech have yet released a driver which makes the camera compatible with windows vista. I too have a clicksmart 310 and have been on the logitech website many times but they still have no drivers.
3answers
Canon MX 310 - printer not detected message
Hi, I will assume that you are installing the Canon MX 310 to a Windows machine. Before going thru the install procedure, please check that you have USB enabled by right click on My Computer, Properties, Hardware, Device Manager, and at the very bottom USB Controllers should be there with no red or yellow markings. If they are not there, please restart your machine, press del or whatever it is to enter CMOS/BIOS setup and verify that the USB ports are enabled. In some instances, it may take some time before the PC recognizes the USB device such as your printer. You really have to give it time or one trick is to Cancel the printer port detection and just go ahead with the installation. When all is installed and finished, you can change the properties of the printer to USB port from the Parallel/LPT1 port. Another is to plug the printer straight in to the USB port (or try all the other USB ports) without installing it first. Allow/let Windows to autodetect and auto install. Put in the CD only when Windows does not know where the drivers/installers are located. Hope this be of some idea/help. Post back should you need further information. Good luck and kind regards.
old marine
old marine
ZJ Limited
ZJ Limited
