Ever since a brief blackout, my internet connection has been down. My Siemens Speedstream 4100 modem has only a red light flashing for the DSL light and the green light is on to signal that the modem is plugged in. The other lights are off. Turning off and unplugging the modem and restarting the computer has not changed anything. What could be the problem.
SOURCE: Siemens Speedstream 4100 Modem manual installion
* You dont need any special drivers to install modem.
* Open up internet explorer, type 192.168.0.1 in the address bar and press enter key.
* Now you should see the configuration page of modem.
* On the left side, click on Advanced button, below that, you will see "connection configuration" option - click on it.
*** If it asks for modem access code anywhere, you can find the code underneath the modem. please type it ***
* Under this page, you have to enter the email address in username field and password, change the connection type to smart keep alive, click on save changes
* Now it may ask you for restart modem. click on restart. within 1 min, you will be connected to internet.
Take care
SOURCE: speedstream 4100 does not work with router
you can't.
when the item name as modem/router. it means the main function is modem with added router function.
you can't connect 2 router/modem together. both need access to the internet and IPS for it function correctly.
however, you can connect 1 modem and one router.
SOURCE: Siemens speedstream 4100 eternet ASDL modem
Hii,
the password and the user name would be given to u by the company from where u have the taken the internet connection ....
SOURCE: connecting a Linksys Cable/DSL Router to a speedstream modem
I have a steps by step guide on how you setup the router.
3. If the internet is
still not working; we will need to adjust a setting on the router setup
page. To access the setup page of the router you need to open your
internet explorer or Firefox on the computer that is hardwired directly
to the router. In the address bar of your browser (Internet Explorer or
Firefox) type http://192.168.1.1/
and hit enter or click Go. It will ask you for a username and password.
Just type "admin" for the password field and there is no username. If
you have ran the setup CD prior to this, then use the password that you
have set when were running the setup CD.
4. Once you
are in the setup page of your router make sure that the Internet
Connection Type is set to Automatic Configuration DHCP, then click the
save the settings button at the bottom of the page. After saving the
settings, click the sub tab at the very top of the page that says MAC
Address Clone. Set it to enable and click the button that will say
Clone or Clone your PC's MAC and save the settings again.
5.
After doing step 4, do a power cycle. Power cycle is done by turning of
the router, modem and computer. Leave them off for a minute, tuned them
back on in this order. Modem first wait for the lights to stabilize,
then the router wait until the power light become solid. Then turn on
the computer. This will get you online through the router.
Check if this will help get the router online.
