I think that the battery might be dead. I could not see how to take the watch apart in hopes that I could pull the battery and then replace. Any ideas? It is a woman's diesel 10bar wrist watch
hey thanks for your quick response. I cannot Identify the lip of which you speak. In fact I can even find a picture of the watch on the internet. It is the dz-4067 (10bar) woman's wrist watch by diesel. Any other suggestions?
You can't post conmments that contain an email address.
Examine the caseback of the watch. You will find the lip (small gap between the case and caseback). This is exact point where to insert watch openers blade and pry caseback up.
Check the battery: Before attempting to set up your watch, make sure that the battery has not run down. If the battery is dead, you will need to have it replaced by a professional watchmaker or authorized Breitling service center.
Wind the watch: If the battery is not dead, you may need to wind the watch to get it started. Most Breitling watches have a self-winding mechanism, but if it has not been worn for a long time, it may need to be manually wound.
Set the time: Once the watch is running, you can set the time by pulling out the crown (the knob on the side of the watch) and turning it until the hands are set to the correct time. Push the crown back in when the time is set.
Set the date: If your watch has a date function, you can set the date by pulling the crown out to the second position and turning it until the date changes. Push the crown back in when the date is set.
Synchronize the time: If your watch has a chronograph function (stopwatch), you may need to synchronize the time to ensure that it is accurate. You can do this by starting the chronograph and waiting for it to complete a full revolution.
Either a dead battery or the watch needs a kick start. Go to a watchmaker as they have equipment to give a kick start. Common problem when people pull the crown out.
did you try installing an other battery ,sometimes batteries are no good. But your problem can be several things, including battery, or installation of battery not done properly. Another issue might be that the watch hands have moved and are bumping into each other and stopping the watch from moving. Check the hands and see if they are touching when you turn the crown. Another issue might be that your movement might be dusty or dirty and will need to be cleaned out. It happens and depending on the age its another likely cause. Those are the easy fixes and most common causes. Other issues involving taking the watch apart or fixing / replacing the coil spring.
If you have a Fossil FS4337 Chronograph, shaking the watch shouldn't be doing anything other than exercising your muscles; the movement is a battery-driven quartz movement whose movement is controlled only by whether the stem has been pulled out (stopping the movement and saving power) or whether the battery still has enough power to activate the stepping motors that move the watch hands. Based on the symptoms that you've described, I would suggest that it's probably time to change your watch battery.
Often, when a watch battery is running low but isn't completely dead, pulling the stem into time-setting mode will stop the movement and permit the battery to "rest," giving it (briefly) a bit more reserve amperage to put out when you push the stem back in. That's how you can sometimes get a quartz watch to run for a few minutes after the battery appears to be dead. That may also be why your watch has started running again after you've set the time and date.
Fossil analog quartz watches tend to use silver oxide (usually #377 or #379) batteries instead of longer-lasting lithium batteries. In ordinary use, I would expect a silver oxide battery to provide between 1 and 2 years of service before it needs to be replaced. I can't remember if Fossil chronographs (which also use quartz movements) use a silver oxide or lithium battery. Lithium batteries often provide an additional year or two of service in analog watches, compared to silver oxide cells; digital watches using them supposedly may last as long as 10 years with a lithium battery, assuming you don't use the backlight or audible alarm functions. Note, however, that these batteries are different sizes and different voltages, so you can't substitute one for the other.
Finally, none of this advice applies if you have a Fossil watch with a true mechanical movement in it. In that case, gently shaking the watch may spin the winding rotor enough to start the watch back up again. However, an even faster way of winding those watches is to use the winding / time set crown to wind the mainspring directly instead of relying on the geared-down action of the winding rotor. Automatic watches can bind up if they are not used for a period of time; the lubricating oil used in some of the pivots can harden--or at least provide enough resistance that the movement may require more initial force to start running than to continue running. That behavior usually indicates that it's time to have the mechanical movement cleaned and re-lubricated.
I don't think storing a watch with the crown out accomplishes much. That I am aware of, pulling the crown out does not break the electrical connection between the battery and the watch. At least in looking at quartz movements, I don't see any electrical apparatus that insulates the crown in any way so that it could act as a switch. I think that in quartz watches that hack, pulling the crown out mechanically disengages or interferes with the drive train, but it doesn't stop the oscillator or stepper motor from running. With quartz movements, at least those I have seen the internals of, (most ETA and ISA designs, some Rondas, a few Seikos), pulling the crown to the setting position does one of two things: 1) On better, jeweled movements - it breaks contact between the coil and battery, thus stopping the motor. The oscilator continues to be powered, but most of the current consumption is from the motor. These pulling the crown out does save battery life. Or,
2) On cheaper non-jeweled movements - it blocks the rotation of the second hand gear, and stalls the motor. These are observable by a "twitchy" second hand when the stem is out. This method actually kills the battery faster, as a stalled electric motor draws more current.
that happened to me too...the watch repair man told me that I had the stop watch on. The stop watch should serve as a stop watch, not the second hand. The second time on your watch is the small dial at the bottom middle of the face. Once I turned off the stop watch feature, my battery life is fine...I have not had to change my battery in over 2 years now. HOpe this helps.
There are a few possible reasons why your watch is not working:
The battery is dead (sometimes even new watches have a dead or dying battery in them).
The plastic piece between the crown and the watch case
was not removed (this protects the battery from wearing down until you
receive the watch).
You bought a watch with a damaged movement or somehow damaged the movement through usage and it just
will not work period so you may have to return it, exchange it, or have
it repaired
These are the 3 reasons why your watch could not
be working. The reason will fall into one of these 3 categories, so I
hope this helps!
We had the same problem with our wall clock, but it was due to corrosion from a dead battery. The battery acid leaked inside and disrupted the connection between the metal contacting the batteries and the circuit (the one with the copper coil). We took everything out cleaned the contact points with acetone (nail polish remover). After that we had to bend the contact heads up just a little bit so they would contact the circuit again (I guess we bent them down a little when we were cleaning it). It worked just fine after that. I know it sounds intimidating to take apart a clock and put it back together but you're going to throw it out anyway. Just give it a try. It was kinda fun. Think of it as a puzzle. If you can't fix it, I imagine you can get a new motor at any hobby store or Michaels.
