Panasonic AG-DVX100A Mini DV Digital Camcorder Logo
Posted on Mar 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Showing warning psd ng in dvx102 panasonic video cam
When the cam is put on, the psd warning is displayed.i need a solution for the same.
Jon Barnes
Level 1:
Scholar:
  • Contributor 48 Answers
  • Posted on Jul 03, 2010
Jon Barnes
Contributor
Level 1:
Scholar:
Answers
48
Questions
Helped
15296
Points
65
PSD NG is an error dealing with the OIS [optical image stabilization]. It can be fixed, it is not as terminal an error as many have rumored it to be. The gyros could be a cause, but very remotely THE cause. You can have the camera sent in to Pani, and they will fix it, and you will get a bill for $300 - $600.
However the main cause for so many, if not all, of the dvx100 series to have the psd ng error is loose cables. If you feel sure of your self with a screwdriver, tweezers, & forceps, you can make the repair yourself. In simple terms, all you need to do is reseat the ribbon cables. Follow the steps & photos here:
http://www.dvxuser.com/V6/showthread.php?t=172290
I did this repair with great success. It was a nerve wracking two hours, but I have not had the error reappear since. I got the camera from someone dirt cheap, [read 1/4 value], because of the psd ng error. I made the repair & not only have a fully operational unit with beautiful pictures, but I also quadrupled the value of it.
Cleverer2
Level 2:
  • Expert 298 Answers
  • Posted on Mar 26, 2009
Cleverer2
Expert
Level 2:
Answers
298
Questions
0
Helped
98915
Points
775
PSD NG means that there is a problem with your electronic image stabilization system.I think Panasonic got stuck with a bad batch of gyros. Take it back if you can, otherwise use lower resolution or hold very still when filming.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1227
Points
Can i get a technician in nigeria to fix my camera panasonic ag-dvx100a that is displaying warning psd ng error code
My video cam shows warning on the monitor, Warning PSD NG
http://www.digital-camera-battery-charger.co.uk
http://www.battery-charger.us
We are committed to the laptop battery, digital camera batteries, camcorder batteries, PDA batteries and Chargers, development, production and marketing services, the products sell well not only 11 years in Europe, America, Korea, Taiwan, Hong Kong and Southeast Asia and other countries and regions, but also through all major cities across the country to establish a sales agent in the form, the establishment of a comprehensive sales network and after-sale service system, the first class products and perfect after-sales service to consumers.
2helpful
Hallo,i am in malang/indonesia i have a problem with my dvx 102b.on the lcd screen theres a warning:PSD NG....what can i do?maybe you can help me to solve the problem,thankfulll for any help
PLease reset your camera then restart and try.
If not success then please visit service center.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Warning psd mg
hello there!
you must disassemble the camera and blow air aiming the ccd block area in the backside of the the lens with a duster spray by means :REMOVE THE LENS AND BLOW AIR FROM 20 cm distance,then reassemble the camera thoroughly and please do not use excessive force while doing it,mini DV camcorders are sensitive in handling ATTENTION qualified personnel only
1helpful
PSD Warning Panasonic DVX 102A
I can help you with this.Disassemble the right side which includes the lcd display,so you can see the lens unit.Use a blower to blow air inside and point it to the lens.Better if you can remove the lens unit and blow air on it with caution and then assemble it back the problem disappears.
PS
If problem insists remove ccd block and apply inside a small amount of grease on the metal axis inside ois coil which is used for moving coil mechanism for optical stabiliser purposes.CAUTION THIS ONLY IF NO RESALTS WITH THE ABOVE METHOD.GOOD LUCK!
1helpful
2answers
PSD NG
Hello! You need to disassmble the side which includes the lcd monitor, so you can see the lens and ccd block area. Blow air inside to clean the parts,and reassemble it .If the problem continues please let me know.There's another way then.
8helpful
3answers
Warning PSD NG Panasonic DVX100A
I checked several forums for you and the general suggestion is just live with it. Panasonic will charge you 330$ to clean the lens assembly and update the firmware and the problem will come back in 2 days. Then they will tell you they have to change the whole lens assembly $550. The problem will come back again. Twenty or more people said the best thing to do is just live with it as it does not interfere with the cameras performance in any way. It sounds to me like this problem is engineered into the camera to milk money from you. All of the users that have just ignored the warning are still working fine, They just say it's annoying.One sent it to a shop to see if they could just disable the warning, You can not. After reading every ones exact same problem I can feel comfortable recommending that you simply follow their course and ignore the warning message. Everyone that sent it in was robbed and the problem came back within a month and ignoring it does no damage to the camera or the video it produces. If I were you I would send Panasonic a letter complaining about this issue and tell them what you know about their scheme. Ask them why so many people are having this problem and they can not fix it. This is just another example of bad business practice. I see this more and more each day in all types of products. They figure you paid a lot for Your camera and you will pay a lot to fix it. Maybe if you make enough of a fuss and threaten to post this horror story to tech forums all over the internet they will send you a better camera. I did that with a Compaq Presario laptop I paid 700$ for. I had to send it in for warranty work 3 times in 6 months. When I threatened to post all my communications with them and my horror story HP Quality assurance sent me a 1400$ HP Pavillion fully loaded just to shut me up. HP bought out Compaq. Apparently these mega companies do not want their secrets out so they will pay you off to settle you issue if you ride them with honest complaints about their bad business practices. The last thing they want is people to realize what they are doing. I hope you found this information helpful. As there is no way to actually fix your problem yourself I hope you find this information I gave you valuable enough to rate it fixya for me. If you ride the company the way I instructed you you will get satisfactory results and in most cases better equipment out of them. And I will get the 6 bucks for telling you how to force them to help you. This is the absolute best answer anyone will be able to give you here. Others may try to tell you all crazy ways to disassemble the lens assembly and cleaning contacts. Doing so will ruin your camera that is not even broken and void whatever warranty you may have or your chances of getting them to replace it with better equipment. In any event, Let me know how you make out. If you need more help getting the company to help you you can send me an E-mail to [email protected] and give me your number and all your info and I will ride them for you on your behalf as your qualified technician. I do this for a hobby so I will not charge you anything. I just hate seeing big companies taking advantage of their customers. Hope to hear from you soon,
George
1helpful
5answers
Warning message
PSD NG is an error dealing with the OIS [optical image stabilization]. It can be fixed, it is not as terminal an error as many have rumored it to be. The caps could be a cause, but very remotely THE cause. You can have the camera sent in to Pani, and they will fix it, and you will get a bill for $300 - $600.
However the main cause for so many of the dvx100 series to have the psd ng error is loose cables. If you feel sure of your self with a screwdriver, tweezers, & forceps, you can make the repair yourself. In simple terms, all you need to do is reseat the ribbon cables. Follow the steps & photos here:
2helpful
DVX-100A PSD NG error message
I think there is something worn in the lens.
I just give the the camera one or two sharp smacks with the heel of my hand
beneath the front body of the camera (not the lens),
That clears it up.
You can probably turn the stablization off too, but I think you also lose some display info.
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
