Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
A
Anonymous Posted on Jul 09, 2017
Badger 5-81 motor buzzing, blades spinning, won't grind
I have a badger 5-1 the blades are free, the motor buzzes, so it's getting power but the disposal doesn't grind. I tried another outlet (thinking it's not getting enough power) I used the hex and it's turning easily, going around and around but when I turn on the switch I just get the buzz, the sound it would make if there's a jam, but there doesn't appear to be anything blocking the blades. Any ideas?
Level 3:
  • Ace Hardware Master 19,187 Answers
  • Posted on Jul 09, 2017
Ace Hardware Master
Level 3:
Answers
19187
Questions
0
Helped
4338817
Points
82259
Replace the whole thing. They are not that expensive and are easy to replace. The issue could be bad motor part or the shaft came loose from the grinding disk.
1 Related Answer
Anonymous
  • 18 Answers
  • Posted on Sep 12, 2009
SOURCE: My Badger 7 just buzzes but blades manually turn.
well you need to take the trap apart and clean out as far as the badger if you can turn with allen wrench the it may be time for a new one they are warrentied it will buzz then throw the in line breaker a button on bottom just push in
It just buzzes
grinder blade is probably stuck or in a bind. Take a socket wrench with extension and from the top (sink), turn the nut and blade inside the disposal by hand to free it up. Can also unplug it and reach inside to see what may be lodged in the disposal (rag, bone etc).
4helpful
Badger 1 1/3 insinkerator not grinding
Hi, Sounds like motor went bad..
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
1helpful
2helpful
There is a buzzing sound, but the blades are not turning.
SOUNDS LIKE MOTOR MAY BE BURNED OUT.
IF SO, U CAN TURN BY HAND, BUT MOTOR
WINDINGS MAY BE FRIED SO IT WON.T RUN.
U MAY HAVE TO REPLACE. SEE IF U CAN
SMELL FOR BURNED WINDINGS.
I turned on the wall swithch. there is a buzzing noise but no movement. blades move freely when i hand turn them. i have unpluged the unit from the wall, still no movement
I think you are talking about a disposal. Since the blades move freely and you have actually unplugged it from the wall, feel all around the bottom of it for a reset button. Even if you have removed power, if this button clicks when you push it, it was tripped. Otherwise, my disposal just did the same thing. The type I have only last for 2 years. Mine buzzes and thats all. The motor has gone out. I will have to replace mine. You may as well.
2helpful
2answers
In-sink aerator makes buzzing noice and wont work even after pressing the reset button.
Are you sure the blade is turning? If its not, there is a hole in the bottom you can fit an allen wrench into to turn the motor and break it free again.
10helpful
2answers
When I turn my disposal on it makes a buzzing ound. the baldes are free. after I turn the blades , I push the red button, and turn the disposal with the wrench, but still just a buzzing sound.
Not good news unfortunately. I would say that either the bearings in the motor are worn out ,so the motor has a hard time turning. Or it may be that one of the motor windings (electric coils) is bad.
I would replace the disposer. If you can purchase a new one just like the old one it will screw right on where the old one was removed.
please mark this answer as a fixya. thanks
Top Ace Hardware Electrical Supplies Experts
Mike Cairns
Mike Cairns
john h
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
