Question about Olympus EVOLT E-500 Digital Camera
My e-500 goes completely dead when shutter is depressed. battery must be reloaded to power on. all other features works fine.
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Reset the camera back to default using the menu... (custom reset and camera needs to be in P,s,a, or M for reset to work) else it is repair
Posted on Apr 07, 2009
Anonymous
SOURCE:
Error 99 keeps coming up I reload the battery turn on off but after a few shots it comes up again and the red shows indicating that it is still processing the shot.
Here is the diagnostic process, allegedly from Canon themselves. It's quite old, a newer camera probably has a SD card rather than CF.
To isolate the cause of the issue, we [Canon] suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the "ERR 99" message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the camera should be serviced.
Jan 19, 2011 | Cameras
In manual mode cannot set shutter speed to
The "--" is the equivalent of the bulb setting with the remote control. The first press of the button opens the shutter and starts the exposure. Another press of the button closes the shutter and ends the exposure. This is so you don't have to hold the button down and risk a bird flying through the beam (and to conserve battery power).
Sep 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
Displays all white in all modes. Kodak V570. Turn the power on and all I can see is white. I have tried a different battery an no battery, just power cord. I know the camera good enough I can go into the...
displays all white because all the color screen have RGB mode if any of mode's are not work correctlly it's mean's color chip was fail and not working. u have to repair ur camera and change ur display screen.
Mar 01, 2009 | Kodak EasyShare V570 Digital Camera
ASROCK K7S8X in power save mode.
when you replaced the internal battery you also reset the cmos adjustments,500 mb ram ? 526 maybe, not alot but won't affect startup,start from scratch,disconnect anything not associated w/start up cd drive,omit video card.and plug monitor into mobo (if there is a d-sub).You need to get to your bio's,restart comp while depressing delete.when bios shows up reload default settings.and start up.you can't resolve this without getting into bio's good luck
Jan 27, 2009 | Asrock K7S8XE Motherboard
Everything works....but hit shutter button & it goes dead.
Hold the power button in the ON position for 10 seconds, then release (obviously making sure the batteries are in first). This forces the camera to do a full reset - you will have to set the time etc when it restarts.
Hope this helps, it worked for me...
Nov 23, 2008 | HP Photosmart R707 Digital Camera
Err 99
Hi Ben ,
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
Let me know if this worked, if not then the camera is dead and it would require some service or a replacement
Thanks
Proton
Aug 07, 2008 | Cameras
Kodak EasyShare CX7530 digital problem
Mine did this until I folded up a small piece of paper to depress and hold the small lithium battery module detect switch inside the battery compartment, then it powered up fine for the first time in two years using NiMH batteries. After removing the paper (lithium detect OFF), it still works. Perhaps that recalibrated the low battery detect circuit?
May 29, 2008 | Kodak EasyShare CX7530 Digital Camera
Err 99
Although you may have cleaned the lens contacts, did you clean the camera contacts? This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
From RICHARD'S NOTES
Dec 04, 2007 | Canon EOS-10D Digital Camera
No picture is taken when shutter release button is pressed
Are those NiMH batteries? Have you tried resetting the camera? If no standard way, just take out batteries for a few minutes, the more the merrier, let the tension build, and replace them. Try tapping on the lens area, it might loose something up. Best I can do, know it aint much ;] Good luck!
Jun 01, 2006 | Nikon COOLPIX Cameras
Why doesn't the shutter button on my EasyShare digital camera work?
The cause and solution may include one of the following: The camera is not turned on. Turn on the camera. The camera is processing a picture; the camera Power ring light (on the Mode dial) blinks green. Wait until the light stops blinking before taking another picture. The card or internal memory is full. Transfer pictures to the computer, delete pictures from the camera, switch storage locations, or insert a memory card with available memory. The shutter button was not pressed. Depress the shutter button completely down. There was a failure in the focus and/or exposure. Press the shutter button halfway to set the Auto Focus (AF) and Auto Exposure (AE). When the AF/AE indicator turns green, press the shutter button completely down. The battery is exhausted. Replace or recharge the battery
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
169 people viewed this question
Top Olympus Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you an Olympus Camera Expert? Answer questions, earn points and help others
