USB port not working in ONIDA Ultra slim 350 CRT TV
How to use the USB port in the TV ?and how to select the input mode?
    New Friend:
India ultra slim 350
21slp350bg
What is the remote number
Posted on Jun 21, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: Input ports are dead
Mine has done the same thing. Verizon Fios tech saaid he has seen this on several tv of that brand. Good luck finding service if you are in a smaller market, mine is over three hours away
Posted on Sep 18, 2007
fougzki
  • 700 Answers
SOURCE: TV not tuning
Resolder the Vertical IC, it might help, or reflux it with a new lead solder. We experienced that. Somehow the vertical IC have some connection on AFC tuning.
Hope it helps.
Posted on Apr 22, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: How do I select PC mode to connect my laptop to my
Here is the user manual telling you how to do it using HDMI or D-SUB15HD.
http://www.retrevo.com/support/Samsung-LN-46A650-TVs-manual/id/17150bh339/t/2/
Posted on Jul 02, 2010
jeisankas-19
SOURCE: DARK PICTURE ON ONIDA COLOUR TV
only for audio but after without vedio
Posted on Jun 01, 2012
ravitimber19
ravitimber19
SOURCE: i have onida 29 tru slim tv how can i unlock the volume because its lock?
how to unlock the all programes in onida true slim 29 inch tv
Posted on Aug 17, 2012
Can I use iphone connected to Bauhn FHD LCD TV via USB port to watch youtubes?
Any device connected to the TV, will display, as long as the TV is set to play the proper "video" mode selected, that device is plugged into. Meaning : if IPhone is plugged into USB, then the video mode needs to be switched from TV reception to USB. Normally this is done by pressing "Input"' on your TV 's remote, then selecting the proper mode.
Mar 16, 2015 | Televison & Video
How do i play movies from a tablet i plugged a hdmi cord but no response
You mentioned a "usb cable" but you cannot connect an external display to a tablet's USB ports. If you are using an HDMI cable, then you will need to select which display is active through the tablet's settings (Android) or control panel (Windows) and also make sure that the TV is set to the appropriate HDMI connection through the input selection.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Dec 31, 2014 | Toshiba 19SL410U 19 LCD TV
CONNECT I PHONE TO VIZIO TV USB PORT AND WATCH NETFLIX.
Vizio doesn't support phone connect - only USB drive (ie thumbdrive type) - With correct USB, TV will show USB as a 'Source' - and if selected will show the files on the USB, but can only open / view folders, images, and video types.
Nov 25, 2014 | Vizio E421VO - 42in Lcd 1080p 60hz Hdtv
How torun a flat panel hd lcd tv on a dell 531s
Please check the input ports on the LCD TV and the output ports on the computer's video card. You need to have a proper cable (VGA, HDMI or DVI) to connect your computer with your LCD TV. Later you need to select your TV's input mode.
Mar 08, 2014 | Dell Inspiron 531s Notebook
How do set the resolution on a samsung 50" plasma (ps50q7hx)
make sure that the tv is in "HDMI" mode. If there are multiple HDMI ports on your tv then check to see which one it is. You should see HDMI 1, HDMI 2, etc. Then when you are sure what port it is in on either your tv directly or using the remote press the input button until the desired input is selected. So for example, if you have it in HDMI port one, press the INPUT button on either your tv or remote and cycle up or down until you select HDMI 1 and that should do it! sorry if it doesn't!
Dec 13, 2012 | Samsung Televison & Video
Where to connect my pen drive in my sony bravia lcd klv32s400a?
Hi Radhika,
Your TV has USB port on back side. Just plug your pendrive there. Then go menu on TV ( use your remote commander) and go to this input. Your TV will read the file on pendrive accordingly.
Regards
Oct 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I cannot seem to link up my projector and laptop computer
Assuming that you have all the connections between the laptop and the projector already performed, you should check in you laptop's manual what is the key combination necessary to switch between normal mode and presentation mode.
For instance, some Dell laptops need you to press the function key (key marked with Fn in blue) and, while keeping it pressed, press also the F8 key (marked with CRT/LCD in blue) to cycle between the options.
Some HP laptops will need you to do the same operation, but now using the function key and the F4 key, to select between "Computer only", "Extended (dual) presentation mode" or "Projector only" modes.
If even with these indications you are still not able to make your laptop show its information through the projector, please send us more details on how you connected your laptop to the projector, as well as the brand and model of your laptop.
Hope this information can help you!
Mar 09, 2011 | Vivitek D825MS Projector
I wondering only,how to connect my hard drive to the LCD TV
Hello.
If you have an external usb hard drive and usb ports on your tv just plug it in. Sometimes the menu for usb drives pops up. If not, try to press source or input select, input on your tv remote. You must see your drive name in the list. Just select it and you should be able to access your hard drive.
Hope this helps!
Feb 13, 2011 | Computers & Internet
Can I play my Ipod on my Lg tv through the ipod
Not if the USB port on the TV says "SERVICE" next to it. At least I don't think that it would work. But go ahead and try it. It can't hurt anything.
Plug it in and toggle through the input modes to see if there's an extra one showing your Ipod. Or look within the MENU settings to see about turning on or accessing the USB port as a video input.
Dec 05, 2009 | LG 32 in. LCD TV
Sharp Aquos - switches input modes by itself, only when cold.
I believe your TV needs the latest version software upgrade. The current software may have been corrupted.
There is a USB service port on the side of your TV. You can download the software to a USB memory stick at sharpusa.com then upgrade your TV from the service port.
If any problems doing this, call 1-800-BE-SHARP and they will run through the procedure.
Mar 31, 2009 | Sharp Televison & Video
Televison & Video Logo
267 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
