RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Posted on Mar 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RCA HDTV MODEL # D52W20 SHUTS OFF AFTER 10 MINUTE.
IT SHUTS OFF AFTER 10 MINUTES. THEN IN YOU UNPLUG IT. OR LET IT SIT FOR A WHILE. IT WILL COME BACK ON FOR 10 MORE MINUTES.
  • TinkerTooler Apr 02, 2009
    I have the same problem.  Unit is an RCA r52wm24 with a ITC222 chassis.  Powers on fine, picture is great for about 15 minutes before fading out completely.  This sounds like a fairly easy fix compared to other problems posted for this model.
TONY BIGNELL
Level 2:
  • Expert 147 Answers
  • Posted on Mar 30, 2009
TONY BIGNELL
Expert
Level 2:
Answers
147
Questions
Helped
43112
Points
326
There is a common power supply problem with these that requires the replacement of four capacitors on the power board. This could be causing your problem.
The t.v shuts its self off
How long does it take to switch off,and is there sound when switching off
Model D52W20.Unit plays and then shuts off and on while whistling.
That sounds like the powersupply is going bad. You may want to unplug unit because it may be a fire hazzard.
1helpful
RCA D52W20 TV powers on fine, then shuts itself off after 5 - 10 minutes. After 20-30 minutes, I can turn tv back on, but then shuts off again in 5 minutes.
it looks like the problem is in the 16v line..try to take it apart..and there's gonna be a 2200mf cap leaky.
that will solve your problem.
I have a D52W20. The set turns on and then shuts
i have the same problem with my set.i placed a box fan behind the set and that seemed to solve the problem if u dont mind noise of the fan blowing
RCA D52W20 52 in. Rear Projection HDTV-Ready Television?
The blue CRT is shorted out. You will need to replace the Blue CRT. You can get replacement CRts at the following link for your model. http://servicemanuals.vstore.ca/
Power issue
Same thing, comes and goes; there are times that it would not come back on for 10-15 minutes... any ideas
2answers
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
RCA TV
Solder bad connections...main board with hv transformer on it..
CL035 capacitor and any others...use magnifier........T.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
