Control Knob turns by hand (clockwise) but does not turn automatically - suspect drive motor has failed or blown fuse ?
Machine does not fill at start of programme. Pump still works and machine will perform wash if filled manually with water - i.e. open door and put in about a litre of water and close door.
Pump will also empty the machine when control knob is moved manually to the correct position.
SOURCE: Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
SOURCE: Neff Integrated slimline - Programme does not complete.
IT SOUNDS AS THOUGH ITS NOT HEATING DETERGENT AND RINSE AID INTRODUCED INTO COLD WATER WILL GENERATE A LOT OF FOAM,IS APPLIANCE WARM INSIDE AT END OF CYCLE?OR IT COULD BE TOO MUCH RINSE AID IF IT IS FILLED WITH RINSE AID AND YOU ARE USING A TABLET WITH RINSE AID COMBINED IT WILL HAVE TOO MUCH TO USE IN ONE WASH.
SOURCE: Neff dishwasher not filling up with water
neff dishwasher will drain water goes in but the top and bottom spray do not work tablet falls in goes through cycle but will not wash. iangas
SOURCE: water wont fill
first of all, i'm gonna guess that the water supply under the sink is turned on.
the water you hear is the left over water from a previous cycle. there is always some left in the hoses after it drains, just like your washer.
this is 1 of 2 things. either your float is stuck in the up position or your water inlet valve is malfunctioning. the float is the quick and easy fix. the float is somewhere inside your dishwasher. it tells the water to stop coming in when it reaches a certain height, just like your toilet. it could look like anything, but most likely a cone or a little hat. just grab it and try to move it up and down. it should slide freely. it was probably stuck up and your handling will have solved the problem. we hope.
if the float was ok, the inlet valve needs checked or replaced. it is under the machine and has the water supply line hooked up to it. good luck
