Ibanez Ael20e AcousticElectric Guitar with Onboard Tuner Logo
A
Anonymous Posted on Jun 25, 2013
How do I tighten the input jack on an ibanez electric acoustic guitar?
5 Related Answers
Fred Yearian
  • 5603 Answers
  • Posted on Jan 06, 2010
SOURCE: would like to know what siz allen key needed to
Read this site for important information:
http://www.ibanezrules.com/tech/setup/truss.htm
Anonymous
  • 109 Answers
  • Posted on Mar 08, 2010
SOURCE: sound is breaking up
Try another cable. If the cable is not the issue start inspecting the guitar's wiring. A bad solder joint or broken wire can cause problems. But I suspect the cable. An easy test if you don't have another instrument cable to try, use a multimeter and test both the tip and sleeve of the cable. You should have continuity on the tips of each end. And the sleeve should have continuity on both ends.
Fred Yearian
  • 5603 Answers
  • Posted on Nov 29, 2010
SOURCE: ibanez acoustic/ electric mandolin top
Take it to a luthier (find one with google or in the phone book) to see if it can be economically repaired.
Fred Yearian
  • 5603 Answers
  • Posted on Sep 10, 2011
SOURCE: my acoustic electric guitar is giving intermittent
A common problem is a WORN jack that is caused by the user NOT looping the guitar cable through the strap or their belt loop. The rotation of the cable as it is played wears both the plug and the jack and causes noise and dropouts. Also verify that the battery connections are corrosion free. Also verify the problem is not with your amp.
Anonymous
  • Posted on Nov 27, 2012
SOURCE: Hi, My Ibanez AEL 20
Ibanez V72ECE hey i bought new ibanez and the tuner not working, i bought new batteries but still cant run. maybe its some way to activate it or its just bad one? [email protected] plx helpme
What type of input Jack do I need for a ibanez guitar amp tbx30r?
i believe you need a 1/4" unbalance plug for the amps input. Basically a guitar cord. If I am understanding the question. ? or if you want to know the actual "input jack",Maybe it is lacking or missing? than that would be a "1/4" unbalanced input jack". good luck, I hope this helps.
What is my Ibanez acoustic guitar worth?
I my market, I see used ones in good shape go for $250. Your market may vary. Of course the condition of your particular guitar is a factor, as well as the market you're in. Music Go Round is asking $289 for one, but I expect it will really sell for $250.
http://www.musicgoround.com/p/534550/used-ibanez-ewc30pderlg1201-acoustic-guitar-brown
Ibanez serial number 82031532 acoustic guitar M330. How much is this guitar worth.
Beats me. Most Ibanez used acoustic models range from $75 to $250. Most sell new for less than $400.
Jul 10, 2013 • Music
Input jack
any input jack should work!
To hook guitar to sound source fendercd60ce
You must have the matching input jack and connecting the guitar cable to the amplifer INPUT and selecting the source will let you play on the guitar.
Check the cables and see they fit correctly.
My acoustic electric guitar is giving intermittent sound any idea how to fix this problem
1helpful
2answers
Ibanez AEL2012E If I leave the double A batteries in, they run down ... fast
The batteries are turned on by the guitar cable being plugged in. If they run down with the cable out, the contact of the "ring" part of the jack is shorting. The "ring" contact is shorted to the sleeve contact to turn on the battery. If you leave your guitar cable in for a day or two, the batteries will run down.
Input wires broken loose, not sure where the go to
The center pin is your tip..which should have a wire going from 1/4" jack to the XLR jack. Pin 1 is earth ground...should be coming from 1/4" jack sleeve. Pin 3 would come from the 1/4" jack ring.
http://upload.wikimedia.org/wikipedia/commons/thumb/8/81/XLR_pinouts.svg/540px-XLR_pinouts.svg.png
If you are still having trouble, post links to pictures of the internals of the guitar showing the assembly.
Mar 27, 2009 • Music
Top Ibanez Music Experts
Ngoro
john h
Are you an Ibanez Music Expert? Answer questions, earn points and help others
