My washer was cleaning a Bulky load filled with towels and two small blankets. It's running with no movement and the lid won't lock. I've canceled the load and unplugged it for 30 seconds. I even reset the outlet. What's wrong and is there a trouble shooting technique?
SOURCE: Maytag washer trouble
If water is going into basket and just not filling up, make sure the end of the drain hose is terminated higher than the basket or the water will run out just as fast as it fills.
If no water coming in at all, the inlet/mixing valve may be bad.
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
SOURCE: Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
SOURCE: how can I make the Maytag Centennial 3.2 agitate
You really can't without redesigning the washing machine.
SOURCE: I have a Commercial Series
Replace the "water inlet valve" on your machine. If you could post your model number I can point you to the part you need.
Sorry hit the wrong button there are some videos on u tube you can look at about your maytag which may help you
