Starter seems to engaged, but after what sounds like a very labored couple of winds it stops. Battery is in excellent condition. Would like to know if it could be cables, starter contactor or solenoid before assuming it is a bad starter? THANX! VInce
Is the oil sump full? Has it been run with out oil? You can do an amp draw test on the starter. Should be 60 amps or so. Can you roll the engine by hand? If engine turns free pull the starter out and bench test it with jumper cables. Positive cable to cable lug and negative cable on the starter case. Hang on to it, lots of torque. If the stater turns slow or gets hot it is probably bad.
How old is the unit? I had one that would not start and I found the choke plate binding. It was a current 14/13KW unit.
Oil was fine. Engine turns easily by hand. Will pull starter and test. Thank you very much for your most helpful advice.
