Brother HL-2040 Laser Printer Logo
Posted on Mar 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't print. blinking red paper light flashing
I cannot print anything.  I have a blinking red light flashing under paper on my brother hl-2040 laser printer.
  • getgap Mar 30, 2009
    no jam and plenty of paper still getting paper warning light?
  • nickcammaran Apr 14, 2009
    The paper is full, new toner, won't print. Drum light flashes and paper light comes on. This is driving me crazy!
Anonymous
Level 2:
  • Expert 54 Answers
  • Posted on Mar 25, 2009
Anonymous
Expert
Level 2:
Answers
54
Questions
0
Helped
21753
Points
203
This usually means your printer is out of paper or there is a paper jam somewhere.
1helpful
Brother HL-2040 paper light flashes red (and won't print) with plenty of paper in drawer
Check for a p[aper jam somewher in the route or at the single sheet feed entry
Brand: Brother Model: HL-2040 Problem: cannot print, paper error, red light blink, did not feed paper. What should i do? thanks.
pull tray out load a couple sheets look underneath and see if paper is lifted up when closing paper drawer. If the paper is not raised to the up position you have broken the tray lift mechanism and it is not worth fixing. You can jam an eraser underneath the tray to manually raise the tray to do a dodgy fix.
1helpful
When I turn on the printer the light paper flashes
The paper light flashing because there is some paper inside the printer. Open the front cover and remove the cartridge and look inside for the jammed paper. Remove the jammed paper and insert the cartridge , closed the front cover and switch on the printer.
It will help you to solve the problem.
1helpful
Red Priner LED Wont stop flashing
it is problem paper jum.please chack it then solve your problem
Printer will not print any documents.
what is the problem the red light is blinking
I have a brother LH2040 printer that won't print
My red light flashing problem on myHL-2040 was caused bythe plastic horizontal rod out of alignment in the back ofthe printer. Steps: 1. Open the back cover. 2. Gently pull the tab toward toopen the Rear Chute Cover (plasticflap) inside (page 78 of User's Manual). 3. Look closely at the bottom rod ofthe Rear Chute Cover tomake sure everything is aligned. The two"tabs"(one long and one very short) on this rod should fit right into theallocatedslots. 4. If not, adjust the rod so theright end extension of therod will block the paper sensor when the chute coveris pushed in by the backcover. Hope this helps - I wasted hourstrying to fix this problem.
2answers
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Norman Weimar
Norman Weimar
k24674
