I connect it to my itunes to update the software then it trys to connect to the apple server but returns error code 1621 and says the error is unknown, how do i fix this?
SOURCE: to fix unknown error 1442
solution is here http://www.apple.com/support/downloads/ipodresetutility104forwindows.html
SOURCE: ipod nano 16gb won't connect with pc(itunes).
Is your ipod nano fully charged? and your installed iTunes the latest version?
Please make sure it is charged, and the new iTunes is downloaded and installed from here please do the following steps:
Connect ipod nano to PC. Make sure iTunes is already open prior to connecting it.
If this is the first time you are connecting then your PC will automatically install Apple Mobile Device Driver.
Once installation of the driver is complete, you should see the ipod nano logo appear within iTunes very soon. and start using it.
SOURCE: ipod mini is corrupted and won't restore
ok try one thing
go through control panel, Administrative Tools, computer management, then disk management .
try to locate you ipod
If present you can format it
ok
SOURCE: i have apple ipod shuffle 512mb, what i do to
i have have apple ipod shuffle 512mb, what i do to solve unknown error 1442. give me solution
SOURCE: I have a nano apple
You need to install iTunes on your computer.
Here is the link:http://www.apple.com/itunes/download/
You connect your iPod to the computer and let iTunes sync it. You can create several playlists and then just drag & drop the playlists you created on the iPod.
If you have further questions, or need further assistance, just leave a comment.
Thank you for using FixYa.
Cheers
Flip the iPod Nano's "Hold" switch to "OFF."
The iPod Nano cannot be turn on if the switch is set to "ON."
Reset the iPod Nano. Move the "Hold" switch to "ON" and then "OFF."
Then, press down the "Select" and "Menu" buttons on the Nano. Hold those buttons for about eight seconds.
The Apple logo will then become visible on the iPod Nano. Once this occurs, try turning the iPod Nano on once again.
Connect the iPod Nano to an iPod charger or a computer that is turned on via the iPod Nano's USB cord. Charge the Nano for at least 30 minutes.
Then, try to turn the Nano on.
Update the iPod Nano's software.
Connect the Nano to your computer via the player's USB cable. Open iTunes, and click the iPod Nano's name on the left part of iTunes.
Click the "Summary" option at the top of iTunes. Then, click on the "Check for Updates" button that's positioned in the middle of iTunes.
Follow the instructions that appear inside iTunes in order to install the updates on the Nano.
hope this helps
