If they are that far gone I would just replace them. I don't know of any way to remove tar stains. The time that it would take to clean them would cost you the equivalent of buying new blinds.
1) For heavily corroded battery terminals theres a simple way to clean...just pour some carbonated soft drink over them and watch the corrosion get eaten way in minutes.....quickest and easiest way isn't it...!! Baking powder and Soda also helps.
2)For better contact of battery posts apply a little amount of Vaseline...
3) Car wipers wearing out..?? Just rub some sandpaper briskly to them to extend their life/
4) The car radio Antenna will smoothly go in & out if you apply some vaseline over it this also extends its life.
5) Peanut butter and laundry pre-wash liquid can work wonders for removing Tar from the Car's finish.
6) To clean & wipe of the snow from your car easiest and quickest way is to clean it with a BROOM. Shorten the handle of the broom for easy storage in the trunk.
7) To properly clean the windshield wipers rub them nicely with Baking powder mixed with water..
8) Tar can be easily removed from the car mats by dropping some LINSEED oil generously over the tar, let it soak for about 15 minutes and then blot it with damp cloth.
9) Newspaper can be used to wipe the windows after cleaning in order to prevent streaks.
10) Want to clean rust over your car bumper....just use some coca cola and aluminum foil over it..
If you would please look at the glass and the metal door in which it attaches, I believe you will see there is a black "tar" that holds it in place.
First, disconnect the electric rear window defroster wire, if you have one.
You would, using a very thin steel wire, separate the glass from the "tar".
Then, clean the tar out of the channel, and prepare the rear door for new tar and the new glass.
It sticks on.
causes:
1) Dusty window motor wheels.
2) Blown window motor.
Check if there is any little knock sound when pushing window up/down knob. If yes you have dusty unit. Needs cleaning and lubricating.
If now try cleaning and lubricating firs, but looks like blown motor.
It is a hydraulic pump that applies pressure to the 2 hydraulic pistons to raise & lower the top. So, check for something obstructing movement first.
The convertible top:
is motor-driven.
requires parking brake engaged to complete circuit for operation.
is equipped with a back window glass (42006) . The back window glass is permanently attached to the folding top back window curtain (52500) and cannot be opened.
professional cleaning sounds like your best deal unfortunatley with what you are describing it will cost @$400 to $500 to clean. If you decided to quit smoking it might take you about month and a half of your cig money to pay for the cleaning
