Ertl International Harvester Farmall Super Mta Diecast Tractor Farm Toy 1:16 Scale Logo
Anonymous Posted on Jun 24, 2013
Tractor hydrolics low
The hydrolics is low, i need to to know where to fill hydrolics
Anonymous
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 34 Answers
  • Posted on Aug 19, 2013
Anonymous
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
34
Questions
Helped
16104
Points
41
Check on back under seat or around there
Ii have a 6640 branson tractor hydrolic fluid has beed changed all filters including internal filter . bailed two bails of hay lost all hydrolic presure again1 any sugestions
Did you fill the new filters with hydraulic oil before you put them back on. If not you will get air in the system which will cause the hydraulics to fail.
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_722ea729aae6fd07
Aug 15, 2016 • Garden
What is wrong when the pto on my kuboto 9000 is very slow about engaging
it could be low on hydrolic fluid i would check that if not that then maybe the hydrolic pump going out
Aug 15, 2014 • Garden
Where do I put the hydrolic fluid in a John Deere 755 tractor?
yvCTPtnpOroaDOyyi9dZt5aw7XkS2RQ">
Little yellow plug is the hydraulic oil fill plug.
Jul 22, 2014 • Garden
Transmission
is the lever pulled out that allows you to push it when its not running?the one on the rear of the mower above the hitch point some you need to remove the trans to fill them
I have a 4120 PowrReverser with a similar problem. Machine was working great. Turned it off to talk to friend. Turned it back on and it would not move, forward or backward. Loader, PTO, and accessory...
You needb to drain the hydrolic fluid and then remove the suction tubethat comes from the right side of the engine and attaches to the hydrolic pump.Loosen the hose clamps and seperate the hose from the tube.Now go under the tractor and remove the brace that goes to the deck.Then go further under the tractor and take the last bolts out of the suction tube.Now you can remove the suction screen and clean it with some solvent and put it back in.Put your tractor back together,install a new hydrolic filter and top up the hydrolic oil,it should move.
710 d has problem in hydrolics ax like main pump is destroking to soon no power in all hydrolics. did presure test found low presure in charge circuit on test port on main pump .have checked or replaced...
hydraulic pump may be going out, you have to have a good working pump for your hydraulics to work right, there are also some check valves that could be leaking, this will also give you a low pressure reading, low pressure will also effect pto engagement
I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
Top Ertl Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you an Ertl Toy Expert? Answer questions, earn points and help others
