Maytag CWG3100A Gas Single Oven Logo
Posted on Aug 23, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag oven will not light
Our maytag oven will not light model number mgr5770abb help....
  • 4 more comments
  • Anonymous Nov 17, 2007
    when we hit the oven temp or broil it beeps and displays F-3
    We have cleared the oven stop and everything else. No results
  • Anonymous Dec 11, 2007
    Our Maytag oven Model MGR5770ADB will initially light and get to temperature, however, it takes much longer than it used to. After it reaches temperature, the temperature starts to drop and the oven fails to re-ignite to hold temperature. We have always had problems with holding an accurate temperature in the oven.
  • Anonymous Dec 13, 2007
    maytag oven doesnot light,broiler does
  • needsomemore Apr 25, 2008
    My broiler will work, but the oven will not get hot at all. I am unsure if there is a pilot light. The manual does not show how to light a pilot light. The warrenty just expired :-(
  • Anonymous Apr 28, 2008
    The burners are working, the touch pad is working, the clock is working. When you touch bake or broil the temperature goes to 100 and stays there. The oven is cold. There is no flame what-so-ever.
    touchpad on stove is working. When you enter bake 350 it goes to 100 and stays there without heating or broiling the oven. There is no flame red, white, green, blue, anywhere, no fire. What is wrong?
Anonymous
Level 3:
  • Master 725 Answers
  • Posted on Aug 23, 2007
Anonymous
Master
Level 3:
Answers
725
Questions
Helped
407046
Points
1785
Have you tried to broil or bake? if only one of them work you have a bad ignitor. let me know and we can go deeper
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 15, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
666
Points
Having same problem.  Broils works.  Oven set to 350 then registers 100.  No gas no heat.  does anyone know the fix?
Anonymous
Level 1:
  • Posted on Dec 11, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
666
Points
T will broil, but the temperature problem is with the bake cycle
Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Where do I find my model number on my Maytag range?
their have an sticker may be in steel where your model number and company name have.if no sticker then you can find it back side of maytag range.
My gas oven doesn't work but the stove part does. The product is only 2 years old.When I put the Bake or broil button on the oven doesn't heat up. I am sure the pilot light is out but I don't know how to...
To answer the question fully, I'm gonna need the model number. Pull out the bottom drawer, and the model should be located on the side of the frame or on the drawer itself. Might even be behing the oven at the top, should be a metal plate that flips up.
2answers
I need to know which kind of plug is used on this oven so that the electricians can install the right kind of receptacle. Maytag cwe5800acs 24 Double electric wall oven
Your oven needs to be hard wired to a junction box. No plugs on a oven that pulls 30 or more amps 220v Read your install book that came with the oven.
Self Cleaning Oven help
It should run with you setting anything but clean. You can obtain a copy of the owners manual from the maytag site or by googling your maytag appliance model number.
Maytag gas oven mgr5770abb Does not light when I try to use oven. Broiler works fine. When I try to turn on the oven, the broiler igniter does not glow. If the bottom igniter was bad, wouldn't the top one...
first I would check to see if you have power (120v) at the bake igniter..when you set in to bake...use a multmeter..(when you turn on the oven to bake only the bottom igniter will come )
good luck be safe
let me know if I can help
There is no reset button on range. Do you mean your house breaker is tripped? I would check for bare wires shorting to ground.
Look for evidence of mice, as in droppings. If so they probably chewed on wires.
Nov 18, 2007 • Ovens
Oven will not work
I had same problem, My solution was to turn off the breaker switch off (disconnect the power) I kept it off for 1 minute turned it back on and it now flames.
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
