I need to reset my nv53 Gateway Laptop to factory settings... I have no disc. I have tried everything but never get the option for factory reset???? It will power up ad then auto-shut-down, and repeats this process until I manually shut it down. I need a way to get in from command prompt or something so I can select factory setting???? alt f10 no good, f1 no good, f11 no good??? I need help??? Thanks
This link may help you:
http://support.gateway.com/s/SOFTWARE/Medialess/FAQ/SUPPAGE01su44.shtml
SOURCE: how do i restore my gateway 7326gz to factory
From a cold boot after you push the start button start tapping f11 it should start your recovery console if it works give me a vote
SOURCE: m6850fx restore factory settings
Well, if you have done all that and no result, then we are going to have to, pull out the "Big Guns" so to speak. Right you will have to get a Windows Vista Install DVD. Boot from this DVD, and try all of the "Repair" options, if they do not work, then you will simply have to re-install Vista from scratch. IE: Boot from DVD and select Install. go through and re-install Vista, unfortunately this will, remove all your old settings, however your files etc, will still remain intact, unless Vista demands you "Format" the drive, in this instance you will loose everything, lets hope it doesn't come to that. I have included a link below to guide you through.
http://windows.microsoft.com/en-NZ/windows-vista/Installing-and-reinstalling-Windows-Vista
You may have to use a friends PC, to do all this.. You can also download a copy of Vista too, and you are allowed to reinstall, as you already own a licensed version.
http://www.microsoft.com/windows/windows-vista/default.aspx
