How can you open an noble safe ce when the battery is dead ?
I have a CE digital electronic safe in my new (to me) motorhome, no combination anywhere to be found and previous owner doesn't know either....how do I get in it???
DO YOU NOT HAVE A KEY AS A BACK UP WE DO SO YOU CAN OPEN IT MY PROMBLE IS HOW TO SET A NEW CODE IN TO IT AS WE DONT HAVE A MANUAL TO IT
When you set a new code by pressing the red button inside, let go of the button, press your combo and press B which is bottom right of the keypad, now to open the safe press your code and then press B....your safe should open.
The manual key entry is a fairly simple lock, try different small keys that fit it and just jiggle the key around while trying to turn the lock....if you have experience you can also use the paprclip method of "raking" to pick the lock.
SOURCE: change code
Try this
Open the safe.
press the red button on inside of door
entry the new code you want followed by B
Should be good
SOURCE: Noble CE Safe Electronic
It´s very easy, you have look for a red button behind the door, press it for 3 seconds and the press the code you want and then press A. Hope you fix it.
SOURCE: I have a Electronic Hardline Digital Safe. I have...
inside the safe door near the hinges there is a red button. Push it and the "proceed" light on the top right of the keypad will come on. enter your new code and "A". That's all.
i pressed the red button inside door was open to the same time and then i press new code with B and then i close door... but new code and old both can not work then. I can not open the door.
Ce electronic gun safe key pad broken
