I have a vaillant 831 combi boiler 7mnths old when i set the timer tappets for the heating to come on it dosnt work i have the room thermastat set to 21
U need to put the little switch to timed , theres of,..timed clock,..then constant.......u need clock face ..ie timedU need to put the little switch to timed , theres of,..timed clock,..then constant.......u need clock face ..ie timed
You can't post conmments that contain an email address.
Check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Cannot find the fault code . There are vidoes on u tube saying how to reset thr code By pressing the reset button . If this does not work youcan ccontact vaillent on there web page . I have a mate who works for them i will ask him as well
on the pipework below there may be a silver braided hose with one or two valves on the end. turn the valve(s) so the handle is inline with the pipe this will allow water from the mains supply into the heating circuit , remember to keep an eye on the pressure gauge. fill the system to 1bar cold then shut down the valve(s). turn on the boiler and it should be ok, if you lose pressure again then you may have a leak somewhere which needs to be found.
sounds like the small heat exchanger that heats water is blocked would advise removeal and cleaning with mild acid mixture taking all the necesssary precautions of course
can not set timer on combi boiler help
