Nokia Lumia 920 Logo
Anonymous Posted on Jun 23, 2013
How do i turn off demo mode - Nokia Lumia 920
Anonymous
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 22 Answers
  • Posted on Jun 24, 2013
Anonymous
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
22
Questions
0
Helped
3793
Points
71
It is impossible to turn off demo mode as handsets in demo mode were specifically manufactured for demo mode. If you purchased the phone and it was in demo mode, please return it to the retailer and ask for a replacement.
2answers
Frigidaire GRSS2652AD side by side model. How do you turn Demo mode on/off on it please?
Demo Mode is used in the showroom to light up the fridge and not provide cooling.
?How to? Turn Off Demo Mode On Frigidaire Refrigerator
GreenCoin.life https://greencoin.life > how-to > off-demo-mode-on-fr...
Here you may to know how to turn off demo mode on frigidaire refrigerator. Watch the video explanation about Side by Side Refrigerator Sabbath Mode Online, ...
Doesn't include: GRSS2652AD ‎' Must include: GRSS2652AD
I have a Frigidaire FG4H2272UF refrigerator in 'demo demo
JustAnswer https://www.justanswer.com > Appliance Repair
Apr 24, 2022 - To put a Frigidaire refrigerator in demo mode, hold the Energy Saver and Adjust Freezer buttons at the same time. Press them for three seconds ...
1 answer · Top answer: great !, Happy to help !
tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
How do you turn off demo mode on a nordic track 2450 NTL 17219
https://www.manualslib.com/manual/583110/Nordictrack-Commerical-2450-Treadmill.html?page=27
Quoting from manual above (may be similar model if not the same.)
7. Turn on or turn off the display demo mode.
The console features a display demo mode,
designed to be used if the treadmill is displayed
in a store. While the demo mode is turned on, the
console will function normally when you plug in
the power cord, press the power switch into the
reset position, and insert the key into the console.
However, when you remove the key, the screen will
show a demo presentation.
To turn on or turn off the display demo mode, first
touch the Demo Mode button. Next, touch the On
checkbox or the Off checkbox.
My oven AZKM755 is locked in demo mode, how do I get it off demo pls.
To turn off Demo Mode:
1. Press SETTINGS 12 times. "Demo Mode" and "ON. Press (1) to OFF" will appear in the display text area.
2. Press the "1" keypad to change the Demonstration Mode setting to Off.
3. "OFF Selected" will scroll in the text area. Demo Mode has been turned Off.
If unable to access the DEMO setting, contact Whirlpool at: https://www.whirlpool.com/services/contact-us.html
How to turn Mode Demo . Off on my Kitchenaid Walloven
No radio rception,player is in demo mode
1. Press and hold the SETUP button for at least 3
seconds.
2 Press the f UP or g DN button to select the
"DEMO" mode.
3 Press the BAND button to turn on or off the DEMO
mode.
Each press toggles between "DEMO ON" and "DEMO
OFF."
If no buttons are pressed 30 seconds after the DEMO
mode is turned ON. The DEMO mode then begins.
NOTE
The initial setting at the factory is "DEMO ON."
4 Press the SETUP button again to return to normal
operation
My toshiba 36in crt tv's demo mode keeps turning it self on
Since I do not have your tv model number so can't be specific, check Demo mode option in Menu and turn it off. Some tvs have selection like Store/ Display and Home mode, store or display mode is demo mode so set tv on home mode to turn off demo mode.
Let me know model number of your tv if you have additional question.
Thanks.
Turned off demo mode but it turns back on on its own
Viewing the demonstration (DEMO) mode
The DEMO mode automatically demonstrates several features of
your TV.
To start the DEMO mode:
1. Press MENU.
2. Press left or right button to highlight the SET UP menu.
3. Press up or down button to highlight DEMO.
4. Press left or right button to highlight START.
To stop the DEMO mode:
Press RECALL, EXIT, or POWER.
I hope this helps. Thanks for using fixya.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
