E-Machines eMachines Desktop PC Logo
Posted on Mar 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have emachine T5010 in 2006. It can't boot.PXE E53 no boot file
I have emachine T5010 in 2006. It can't let me start this morning. I got the following message in black screen:
PXE M0F existing ...
Ichange the boot sequence, change battery, check every connection.But no effect.
Anyone could tell me how to fix this problem?Now i try to use system recovery in DOS. how to do that. could anyone help?
  • helenyhz Mar 25, 2009
    Thank you for your help!
    I try to reinstall the system. but I can't use the system recovery that installed in partition because i can't boot the system. I use windows xp cd to get into DOS, but i don't know how to recovery my system , anyone can help.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 16, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
759
Points
I had the same problem. I changed the cable (ribbon) to the hard drive and turned it back on and it started reading the hard drive again
Anonymous
Level 2:
  • Expert 133 Answers
  • Posted on Mar 25, 2009
Anonymous
Expert
Level 2:
Answers
133
Questions
0
Helped
34409
Points
289
Ii think its a virus, nothing else. if its a virus u will also notice that your PC has become much slower than before, the thing for u to do is doa virus check and if u wanna be even more safe you gotta reinsatll ur OS and format ur HDD.
hope i helped, thanks, bye.
ERROR : F3-F100-0003 when running recovery disc for Toshiba Satillite L755-25217
Just format your Laptop because your operating system is damage.Install another Operating System that's all.
2answers
My dell computer says PXE-E53, on RealTek PCIe FE Family Controller Seriies V1.19: No boot filename received and then says no operating system found
First go to bios by press f10 (or kay for your model of laptop )and
select main menu and check display cd dvd drive and hard drive in information.
select cd dvd or hard drive to first boot .set network as lower than hard drive.dell-bios-uefi.jpg
in this pic netework is high piority for boot up. but there are no network server to boot up. there was showed as no network device, pls select hard drive and select key for change setting.
Black screen with error:pxe-e53 no boot file name received
re-installtion/recovery needs to operate normally again
My cf29 Panasonic toughbook have no boot file name/ pxe-e53
This error is a network boot error.
The error message indicates that the client received at least one valid DHCP/BOOTP offer, but does not have a boot filename to download.
A fix to this problem is found on this WEB site.
http://www.bootix.com/support/problems_solutions/pxe_e53_no_boot_filename_received.html
Pxe-mof exiting pxe rom
If you are not booting from a network, PXE-boot is the wrong boot option.
You have to change the boot order so that the PC will boot from your HDD. This can be set in the boot option in your BIOS.
Depending on the type of BIOS, you will enter F2 or Delete during the POST( when the white letters appear on the screen after you turned it on). This will enter you into the BIOS setup. boot options are usaully the last tab. Either disable the PXE-boot or change the priority so that it boots from the HDD first. Please, if you are unformiliar with this, reference the manual or ask someone with some IT background.
If the problem still exists after you configured the boot options your hard disk drive might not be readable. The BIOS just goes to the next availible boot device.
1helpful
2answers
When turn on computer NO WINDOWS XP .On the screen was PXE-E53 : No boot file name received PXE-MOF: Existing Broadcom PXE ROM Operating System not found
That means your computer trying to boot from LAN port. Go bios and change the settings of PXE boot to disable and make Hard disk as first boot device. Save the settings and restart your pc. It will work
I have Dell Studio 1555, Vista but later intalled XP on drive D, I have problem my CD/DVD drive does not read the Data, CD does not revolve in high speed make the tak tak sound as it try to read bit after...
Your message indicates that Pxe Boot is enabled (boot from lan card), go to bios settings and from the list of first boot options, please select the hard disk (hdd) or Cd-rom as the first boot device, reboot your system and check whether this helps or not.
It is also necessary to disconnect and reconnect your dvd/cd rom's power cable and data cable.
If you don't know how to do, then just reset the bios settings to "load default" ...
Good luck.
Thanks for using FixYa.
2answers
Pxe e53 no boot filename recieved,
check your harddisk is detected or not in bios setup
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
