I have a Coleman 2400 PSI pressure washer Model # PW0872400. I have minimal to no pressure on the output. I did have pressure until I tried to adjust the unloader valve. Could this cause the problem. Where is the Pressure adjustment made? Is there a Service manual available for this model.
Pressure control valves are non adjustable
They operate to unload the pump when the trigger is released
What can vary pressure is the jet size at the end of the wand
The screw and nut on the valve is only to regulate the stop/start pressure as the trigger is pressed/ released
low pressure at the wand jet can be from low water supply to the pump or pump internal problems
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
