Originally Posted by
3FingeredGlove
We can make this work. You didn't mention which setup code you're using, or explicitly say whether the OK/Select button is red or gray (the manual you're using is for gray), so these are somewhat generic instructions. Should work, though. This will provide a power toggle function to the Power key.
Use red numbers for the red OK/Select button remote, grey numbers for grey button remtoes.
Temporarily assign setup code 30842 or 0842 to AUX1) Tap AUX
2) Press Setup until 2 blinks
3) Enter 30842 or 0842The remote should blink twice
Assign NEC1 IR protocol device 210, subdevice 108, function number 203 to Power (you don't need to understand these numbers)
1) Press Setup until 2 blinks
2) Enter 994 (2 blinks)
3) Tap Setup
4) Enter 00051
5) Tap Power (not All On)
Assign setup code 30135 or 0135 to AUX (this is NEC1, 210.109)
1) Tap AUX
3) Enter 30135 or 0135
I have just bought an Onkyo HT-S6100 Home Theatre system and have the same problem. The Onkyo website, and Manual both list Motorola and General Instruments devices under Cable set top boxes, but nothing under Satellite set top boxes.
I have contacted Onkyo Tech Support but they were not very helpful. They simply told me the codes were "correct at the time of publishing" and subject to change... Then suggested I try the Cable box codes.... (That was the first thing I tried)
Anyone have any other suggestions?
Any answer please send it to [email protected]
Remote code for starchoice receiver with any onkyo system will be correct.
the code has to be 5 digits,
thks
