Question about Cameras
Nikon d50 wont take pictures FEE flashing in display window
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
You're apparently using a lens with an aperture ring. Turn the ring to its smallest aperture (largest f/number). If the ring has a lock, lock it in place. You can control the aperture from the camera body, the same was as with a lens without an aperture ring.
Posted on Jun 22, 2013
6ya staff
SOURCE:
Anonymous
SOURCE: Nikon D50 LCD Display does not work
NatD, The D50 and indeed most SLR digital cameras [ I have a D40 ] does not allow you to take pictures using the LCD display ... this is by design, you are meant to use the viewfinder and the image you see through it is straight through the lens via a mirror block [ called a reflex pentamirror or prism ]. When the mirror is down such that you can see the image in the viewfinder it is obscuring the sensor [ the bit that takes the picture ] and when you take a shot the mirror lifts and the picture is recorded. Its this reason that DSLR's dont use the LCD to shoot, however there are a few now available that do let you do this, such as olympus, new panasonic one and higher end Nikon and Canon cameras. Hope this explains it without getting too detailed!
Posted on Dec 06, 2007
Anonymous
  • 667 Answers
SOURCE: aperture
You need to set the aperture ring on the lens to the minimum f-stop number, i.e. f22,f32. The camera controls the aperture rather than a mechanical setting on the lens
Posted on May 28, 2008
Glyn Kendall
  • 146 Answers
SOURCE: MY NIKON D50 SCREEN HAS
This screen shows areas of the photo that are overexposed slightly.
It flashes them to help you.
You get to this screen by pressing the up or down arrows when displaying the pictures you have taken.
To change it just press the up arrow when the camera is showing the screen until you get a display without flashing.
Once you have done this the display will be steady.
If you get any other screen in future you may have accidently pressed the arrow again.
Just cycle thru the displays to get back to steady.
Posted on Jul 23, 2009
praky16
Prakash Ram
  • 744 Answers
SOURCE: Nikon D50 Flashes Err and clicks
hi..
thank u
rate me!!
Posted on Jul 27, 2009
Anonymous
  • 181 Answers
SOURCE: sigma 18-300mm lens
The problem may be with the sigma's aperture ring. Try this:
- Turn camera off
- Turn the aperture ring clockwise and lock it
- Turn camera on
If this does not solve the problem, do it again but turn it counter-clockwise
Posted on Jan 04, 2010
Testimonial: "thanks for the advice camera now back in working order. thanks again."
Nikon d50
If this is not the case, please specify the lens you have mounted on your camera.
Jun 23, 2013 | Cameras
Nikon d50 wont take pictures and displays r10 warning
R10 is not a error code, it tells you how many pictures (on average) the camera can shoot before it has to stop and clear its internal memory by writing to the SD card.
Is there a card in the camera? It will not fire without one. Also, if you have taken 20 or 30 thousand exposures, then the electronic switch (not the button on the top) that fires the camera may be worn out.
Jun 30, 2011 | Nikon D50 Digital Camera
hi..
thank u
rate me!!
Jul 27, 2009 | Nikon D50 Digital Camera
MY NIKON D50 SCREEN HAS THE WHITE AREAS OF PICTURES FLASH BLACK AND WHITE
Jul 21, 2009 | Nikon D50 Digital Camera
N75/ fEE
The camera requires you to set your lens aperture at the minimum setting, usually orange coloured. I.E. f22 f32. Nikons control the aperture through the camera, not setting the ring manually like old style SLR's
Feb 25, 2008 | Nikon N75 with 28-105 lens 35mm Film...
Sigma 170-500mm APO lens on Nikon D50 won't autofocus or shoot
When you get a flashing EE, it means there is an Eror somewhere. Most cameras have a botton you press to reset it. Usually it is the battery check button. Try that. Also try taking the lens off the camera, unlocking the aperture ring, remount the lens and then lock the aprture ring to the minimum F stop. I think this should solve the problem.
Aug 06, 2007 | Sigma APO 170-500mm f/5-6.3 DG for Minolta...
Nikon D50
I have this problem too - Nikon have looked at the camera and said I set up a custom setting so that the focus only works when you press the AE/AF Button (!). I also had a problem with the flash not working - its looking like this is a known problem. I think I was sold a Turkey
Apr 19, 2007 | Nikon D50 Digital Camera
Cameras Logo
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
